Old 10th January 2002, 04:38 AM   #11
I veneered my speakers with some self adhesive veneer. I found it at the local lumber shop. I had never seen it before. It had some 3m adhesive on the back and a peel off cover. Went on just like contact paper. Couldn't have been better for a first time veneerer.
Old 14th January 2002, 01:44 AM   #12
I veneered my kit speakers with some iron on melamine which went on fine and the panels look good but finishing the edges was a nightmare. Even using an edge router requires a spacing jig to keep a consistant edge.
I did some others using an iron on wood veneer which has the huge advantage that you can use a sander to cleanup the edges. It does require staining and varnishing to finish but looks very nice when completed.
Speaker Cabinet Finishes cyberspyder Multi-Way 34 30th March 2009 10:03 AM
Suggestions for quick, good looking finishes The Paulinator Multi-Way 3 29th January 2008 04:49 PM
Faux paint finishes (revisited) Mos Fetish Multi-Way 8 14th May 2007 03:10 AM
Finishes -- FWW article on foam brushes jackinnj Multi-Way 16 17th August 2005 02:14 AM
Safe HVLP finishes? tiroth Multi-Way 21 7th February 2005 05:25 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
