I cannot find offers of follow ribbon models:
1) RBN401 2) RBN601 and the largest ribbon driver of the world: 3) RBN1801 Alcons Audio launches its largest ribbon driver RBN1801 alcons audio - evolutionary audio solutions ® only complete loudspeakers are to find, e. g. alcons audio - evolutionary audio solutions ® alcons audio - evolutionary audio solutions ® Kompakte Alcons SR9 2-Weg Box jetzt lieferbar but also without price offers Who knows delivery sources that can offer both complete loudspeakers and only the ribbon drivers? The Stage Accompany is an alternative. Stage Accompany: the end or not? AMT ESS-1 vs. Stage Accompany SA8535 (SA 8535) Which other alternatives to this ribbon drivers are on the market? Perhaps the "RT-7 pro" (RT7 RT7pro) from Expolinear? http://www.hifisound.de/oxid/out/oxb...XP-1012690.pdf http://www.createforum.com/petereuro...orum=petereuro Last edited by tiefbassuebertr; 23rd September 2010 at 09:34 AM. |
#2 |
As far as I know, Alcons drivers are not available to anyone, not even OEM customers, only as finished Alcons speakers. I know a few speaker manufacurers who have tried for years to buy Alcons drivers... with no luck so far.
SA is possible to get hold of I know. I would rather look at the various AMT alternatives out there...
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles |
#4 | |
Hello, I am currently using the Beyma TPL-150H (the horn loaded version) and I am really pleased about its qualities. What I would really like, though, was to take these qualities much further down in frequency, say down to 600 Hz. Unfortunately this is not possible with the TPL if you still want to play loud (and I do!). This restriction made me look around for large, high efficiency, pro ribbons. Thus, I have also asked Alcon Audio about their monster ribbons, but I got a firm answer that they did not sell single drivers at all. Another interesting option might be the serious ribbons from Transmission Audio: www.transmissionaudio.com At one point I enquired about their ribbons, but never got a reply. Finally, there is the chineese manufacturer Akip Lab, who makes the PA-108 driver: Akip lab - Professional ribbon speaker manufacture This driver should load down to 600 Hz, but when the company heard that I enquired as a private person and not as a company, I never got further replies. Actually, the Akip Lab PA-108 looks a lot like the ribbon used in the fairly new high efficiency speaker from DIY-Hifi supply:-) Best regards Peter |
#5 |
#6 | |
Do you (or someone else) have any idea how far down in frequency the Fountek Neo Pro5i could be used in you for instanse stacked a pair of them and hornloaded them? Thanks! Best regards Peter |
#7 |
I've measured the NeoPro 5i. It has a rather pronounced resonance around 900 Hz, so I would not run it farther down than say 1500 Hz, regardless of loading.
The big hornloaded Beyma TPL-150H can be used down to 8-900 Hz if you put it in a fairly wide baffle to lower the horn cut-off somewhat. The TPL doesn't have any obvious resonance either.
#8 | |
I have my horn loaded TPL's on a 50 cm wide and 30 cm high baffle, and under these conditions it loads rolls off below 1300 Hz. It may go further down in frequency on an even larger baffle, but in my setup I would prefer not to place the TPL further away from the mids. Besides, the directivity of the horn is only constant down to 1300 Hz, but maybe on a larger horn!? It is a great tweeter, and taking these qualities down to the mids would be very attractive indeed! Best regards Peter |
#9 |
I also used a 50 cm wide baffle for the TPL. What I did when crossing over at 900 Hz, was to use the natural roll-off as a part of the crossover, enabling a 4th order slope with just a 2nd order filter topology. That way it was possible to cross at 900 Hz even if the driver itself rolled off earlier. I didn't observe any downsides doing that, and power handling was certainly not a problem. The speaker (which also had two reflex-loaded 15" woofers) could play exceptionally loud with a 1000W amp without much complaint from the tweeter.....
#10 | |
Thanks for the reply! I may try to lower the crossover then! I still wish Beyma would make a giant version of this driver, though Best regards Peter |
| Ultimate sounded Cone Tweeter Overview without Ferrofluid wanted | tiefbassuebertr | Multi-Way | 13 | 2nd September 2011 02:07 PM |
| Ultimate sounded Class D for diy without custom made IC's like Tripath TA2020 | tiefbassuebertr | Class D | 38 | 17th June 2011 09:49 PM |
| How to get Alcons RBN 1801? | elac310 | Planars & Exotics | 1 | 1st March 2011 01:21 AM |
| Ultimate sounded ZEN (Var I) vs good sounded used Aleph 5 | tiefbassuebertr | Pass Labs | 17 | 2nd April 2010 03:52 AM |
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. | kimbal | Tubes / Valves | 4 | 11th May 2009 08:05 PM |
| Page generated in 0.14228 seconds (79.21% PHP - 20.79% MySQL) with 11 queries |
