Old 18th September 2010, 11:38 AM   #1
grahamfocal's Avatar
Default Upgrading from dome conventional to ribbon
I am considering upgrading my cloth dome tweeter with a ribbon, where is the best place to start the mod, do I have to upgrade my crossover and is there any guides to the process. I am fairly competent with loudspeaker design, but ribbon tweeters is a new area for me, but know that I have heard many and love the sweet clear detailed sound.
My speakers are the QLN reference (about 15 years old)
I think that the drivers are scanspek at the moment (doped paper bass drivers and a normal dome fabric tweeter)
I've got an idea--an idea so smart that my head would explode if I even began to know what I'm talking about
Old 18th September 2010, 12:05 PM   #2
Below is a picture of a vintage Acoustic Research model 3 speaker. I replaced the old dome tweeter (first of it's kind) with a Fountek (NeoCD3.0) ribbon. The owner loves the sound better than other modern tweeters (even Scanspeak) I've installed in aother speakers he owns of the same type (3a's etc.). He's come back to me and wants to schedule changing over his other AR's to the same ribbon.
The original model 3 had a 1st order xover on the tweeter (single cap). I went with a 2nd order targeted at the same xover point of 5 kHz to help protect the delicate ribbon. In this case, the xover point was much higher than the Fountek stated freq. range low end of 1.4 kHz. If your xover point is closer to this level, then go with a 3rd or even 4th LR type which will also minimize distortion.
Old 18th September 2010, 12:17 PM   #3
Thats brilliant, thanks, I was just concerned that I had to do something special with the existing crossover in the loudspeakers.
At this stage I simply wanted to try by swapping the cables from the rear of the current tweeter and trying them on a ribbon? can I do that then without damaging the amp or ribbon tweeter,.
Old 18th September 2010, 12:21 PM   #4
You may have to revise your xover depending on what you have.
Just follow the guidelines I stated in the second Paragraph of my earlier post.
Old 18th September 2010, 12:26 PM   #5
Will do thanks.
Wich is best : ribbon or dome tweeters ? lduarte1973 Multi-Way 31 25th April 2012 01:21 AM
ATC mid dome and ribbon tweeter Vil Multi-Way 69 16th September 2005 09:08 AM
Tweeter Box Crossover with Ribbon and Bullet Dome Tweeters doccbst Planars & Exotics 2 5th August 2005 04:54 PM
ribbon vs dome tweeters MyNameIsJake Multi-Way 15 21st April 2005 09:17 AM
Using a Visaton Ribbon with a Morel MDM55 dome mid Chagall Multi-Way 4 18th June 2004 06:13 AM
Page generated in 0.09800 seconds (69.24% PHP - 30.76% MySQL) with 11 queries
