Old 18th September 2010, 09:08 AM   #1
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Question nonidentity of the two compression drivers
I bought a pair on sale (cheaply).
I was not expecting a miracle for $ 60, although the difference of the resonance frequencies of 130 Hz seems to be too big.
but the difference in the graphs of 2kHz I do not understand. What causes this?
flesh flash flush
Old 18th September 2010, 09:20 AM   #2
R.I.P.
You likely need to open them, inspect, and clean the gaps, also verifying that the diaphragms are the same.
Then, measure them on a horn or waveguide, with proper loading....
Old 18th September 2010, 01:04 PM   #3
Flaesh's Avatar
I have no 1" horn\wg now. may be tomorrow..
FR with corresponding difference at 2kHz:
flesh flash flush
Old 18th September 2010, 02:36 PM   #4
Pano is offline Pano  United States
Pano's Avatar
Get then on a horn, then the measurements will mean something. But don't expect them to match too closely.
Compression drivers or cone drivers - what do you prefer? Defo Multi-Way 25 28th February 2010 10:57 PM
Compression ratio and diaphragm size in compression drivers inkasound Multi-Way 50 8th January 2009 03:38 PM
compression drivers edwgreen Multi-Way 2 29th November 2006 04:38 AM
21" Bass Drivers and Beyma Compression Drivers Magnetar Swap Meet 0 19th November 2006 02:42 AM
Page generated in 0.24527 seconds (20.83% PHP - 79.17% MySQL) with 11 queries
