Old 4th July 2003, 10:56 PM   #1
Guss is offline Guss  Canada
Guss's Avatar
Default Sweet tweeter
The short story...
On my last 3 DIY speakers the tweeters sounded harsh every single time. Now I really want to get bright sounding speakers but I dont want them to sound harsh. My question is : is there any of 1st,2nd,3rd order that could help me fighting against harhiness? Any other kind of filter, I want to get some advices...
Next driver would be a Peerless 811815 1" DOME TWEETER.
can be found herehttp://www.partsexpress.com/pe/pshow...=277-408&DID=7
thanks
Old 5th July 2003, 08:43 AM   #2
The Scanspeak d2010 has a reputation as sounding very sweet but it only has an efficiency of 91dB (closer to 88 once it's hooked up to a second order XO).
if you can tolerate the lower efficiency then it's actually a pretty low cost option.
hope this helps a little
Drew
Old 5th July 2003, 02:11 PM   #3
Guss's Avatar
thanks a lot
Old 5th July 2003, 03:24 PM   #4
Guss:
Very often tweeters have sensitivities that are a few decibels higher than the woofer/mids they are crossing over to. This would tend to give a harsh sound.
Perhaps an L Pad or some other way to bring down the tweeter output might help?
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 5th July 2003, 04:06 PM   #5
Guss's Avatar
BUT I ALREADY USE L-PAD! this is why I asked if any order in particular would make my tweeter sounds sweet. As I can't afford scan speak drivers for the moment I'll buy peerless ones.
Old 5th July 2003, 05:54 PM   #6
Raka is offline Raka  Europe
Raka's Avatar
My current commercial speakers are Advanced Acoustic and use the 811815 tweeter. Not harsh at all. I think you will like it.
In my unit, is crossed over with a single 4.7uF and a pad resistor. In my short experience, the first order (if possible) makes a more natural sound, and the harsness comes from the medium range.
What price do you have for it? I'm also planning to use it in a Diy speaker I'm building for a friend maybe crossing at 2Khz
What is beyond the speaker?
Old 6th July 2003, 12:00 AM   #7
Guss's Avatar
I'd say between 40 and 50 $ max. I wont crossover that low just to enjoy my mid/woofer large range. For the crossover, I will use solen caps and coils. What do yo plan Raka?
Old 6th July 2003, 12:58 AM   #8
7V is offline 7V  United Kingdom
7V's Avatar
I'm going to have to whisper this one as I don't want to start a whole big thing here ...
C37
Alternately, use Bandor 50mm (2") drivers and do away with the tweeter altogether.
Bandor Drive Units
Steve
Old 6th July 2003, 01:11 AM   #9
Guss's Avatar
WTH ! Those speakers are damn good !
first - where can i find them ?
twice- how much
Old 6th July 2003, 07:16 AM   #10
I have two recommendations. I have found that really old, lower quality CD players will start sounding harsh before the rest of the sound goes bad, so just to be sure, you might find someone with different components than you have so you can swap them out and make sure you don't have a weak link. The fact that a few different tweeters have had the same undesirable sound is a bit suspicous of something OTHER THAN the tweeters, if you ask me.
I also agree with the other guy's recommendation of using more of a full or partially full-range driver like a 2" or 3" Tang Band. That takes the crossover frequency out of the delicate range of most vocals, and I own the 3" Tang Bands with the neodymium magnet and I can tell you that they are NOT harsh. Smooth as anything I have heard.
I need help on a sweet project mryoumans Everything Else 3 16th April 2008 12:33 PM
Arta is SWEET!! ch83575 Multi-Way 7 23rd February 2007 12:27 AM
Looking for advice on "sweet" tweeter? Leonidas Multi-Way 7 20th February 2006 08:25 AM
Sweet! (Bag End InfraSub) BAM Subwoofers 5 13th January 2002 04:13 AM
Page generated in 0.11606 seconds (79.74% PHP - 20.26% MySQL) with 10 queries
