Hi guys,
I've been using Clio (currently 8.51) for 3 years. Is there many more Clio users here? I'd be interested to hear how widely used it is? For what you use it mainly? And to exchange experiencies, best practises, rants, hints and so on. Cheers, Timo |
#2 |
R.I.P.
Yes, 8.51, and about the same duration.
Directivity maps are my current "kick." A dozen EconoWave designs with it since the first of this year are documented here: Flex Your PCD Mettle: - Techtalk at Parts-Express.com You'll see one done using HOLMImpulse when I updated to USB and 8.51, verified with CLIO afterward. Originally purchased a used ISA version and immediately upgraded to PCI factory direct, V6.5, as I recall, later 7.x, and now, 8.51.... |
#3 |
I have CLIO as well. Still using 7.11, great software. I use it with LEAP Crossover Shop. I do DIY and DIY clones.
Rob
"I could be arguing in my spare time" |
#4 |
R.I.P.
Rob, your started with "Lite" and upgraded, as I recall.
Was that a good option? |
#5 |
Hello Zilch
Yes it was, it was cost effective at the time. The upgrade was actually less expensive than purchasing the full up package. Not sure if the same holds true now. Rob
#6 |
It's good to hear there are more Clio users! I'm going to ask a question right away: How do you compensate for excess phase when calculating 'true phase'?
Do you do it through Group Delay(excess), look it from curve and then enter it to Time Shift box in Processing Tools (like it's decribed in manual)? When ever I do that I have trouble finding any good number for time shift because group delay curve is not flat. Like in this attached file: group delay changes between 2.95 and 3.3ms in area between 1 and 2 kHz. That is huge difference and will throw phase totally upside down. Thanks, Timo |
#7 |
I have version 4.5 ... its really old, but works great! Anyone with an even older version out here?
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles |
#8 |
I don't use CLIO anymore...I went to Praxis because I wanted to make my system more portable than was easy with CLIO...but I used CLIO for a long time.
In response to the excess vs true phase...this may sound a little silly, but what I found worked best for me was to leave time of flight in the measurement when exporting to your design software of choice. Now you don't have to enter any number in to your design software for acoustic centers being offset since it is all contained within your phase data and there is no room for error. Then after all that if you want to clean up phase to get a better idea of what the "true phase" looks like then have at it. |
#9 | |
Enjoy good sound
Of course, version 4.07! Still works great. ![]() Anyone with an older version?
/ Anders |
#10 |
I still have and use both Clio and LMS. I wish there was some way of using ISA boards in a modern computer but my old cluncker still works.
![]() Terry
What we don't understand is called magic. |
| FS: Clio Lite | mdlover | Swap Meet | 6 | 27th September 2007 07:12 PM |
| Help with CLIO DOS | meil | Multi-Way | 0 | 9th July 2005 05:32 AM |
| Requesting CLIO Data | teodorom | Multi-Way | 0 | 19th June 2004 08:11 AM |
| Looking for Clio Win | fanta | Swap Meet | 0 | 24th August 2003 06:45 PM |
| Page generated in 0.10110 seconds (81.07% PHP - 18.93% MySQL) with 11 queries |
