Old 2nd September 2010, 09:34 PM   #21
R.I.P.
Originally Posted by serenechaos View Post
Maybe listen to Toole's work first,
is that really the sound you want???
That's what Toole is about -- correlating loudspeaker measurements with listener preferences. His work tells you what most everyone else likes, statistically, and how to achieve it. If you like something else, that's fine, too, but there is value in knowing the difference.
I believe I have made a credible case that classical music enthusiasts preferring the sonic character of an acoustic concert hall want a different voicing. That's Linkwitz's target, in my view; he's designing for a niche demographic....
Old 3rd September 2010, 12:59 AM   #22
john k...'s Avatar
So where are they sitting in what concert hall? Front row center? Second balcony?
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
Old 3rd September 2010, 02:09 AM   #23
R.I.P.
In the "best" seats, of course, of the "best" halls, certainly not what the conductor hears....
Old 3rd September 2010, 02:47 AM   #24
Pano is offline Pano  United States
Pano's Avatar
I don't know what seats, but Mr. Linkwitz has told me his only comparison in voicing is live sound. He does not listen to other speakers. (I'm sure he hears plenty, they are hard to avoid - but does not use them as a reference).
From reading his stuff, his "live sound" seems to always be the concert hall.
Old 3rd September 2010, 02:56 AM   #25
R.I.P.
Yes, and it's not the "Led Zep Live in Concert" concert hall we're talking here....
Old 3rd September 2010, 03:00 AM   #26
Pano's Avatar
He, he. No, not likely.
Old 3rd September 2010, 01:05 PM   #27
john k...'s Avatar
Originally Posted by panomaniac View Post
...Mr. Linkwitz has told me his only comparison in voicing is live sound.
The real problem I have with this statement and all the hype about the Orion 3.2.... is that the Orion has been a round for, what, 8 years now. Not to mention the Phoenix before that and all his other designs. The Orion is, "Last speaker you will ever own, etc...." SL has always said that he uses live music as his reference. So after all this time he finally has it right?
Both the Orion and my NaO II have similar flaws regarding the integration of conventional dome tweeters. I tried to reduce the problem by using a narrower baffle and higher x-o pointin the NaO II, but it is still present. The problem is with the power response. I discussed this on my web site 4 years ago in my article on integrating tweeter with dipole mids . The thing is, what is important is the spectrum of the direct sound and the relative ratio of direct to reflects sound, and how this varies with frequency. Understand that by reverberant sound field I am thus limiting the discussion to that region above the sparsely populated modal frequency range. The problem with speakers like the Orion and NaO II is that the power response is not monotonic. It increases sharply through the crossover point before dropping off due to tweeter directionality. I believe, and I think it is faily well accepted, that power response should be relatively constant from about 100 Hz up and then to drop off somewhere around 4k Hz. Now, that is what should reach your ears. It is a lot easier to accomplish that if the speaker radiates power in that way to begin with. But as discussed on my site when a dome tweeter is added to a dipole mid the power response is anything but monotonic. If you look at Figure 5 on the web page I reference above look at the transition between the red dipole mid curve and the blue or green tweeter curves. The blue is representative of a front only tweeter, the green, front and rear tweeters. The figure is based on flat on axis response. From it, it is obvious that the only way to correct the power response would be to change the on axis response from flat. But there are several caveats. If for example you were in an anechoic room, there would be no reverberant field and therefore power response is a non issue. All that matters is the direct sound associated with the on axis response. When we move into a more reverberant room, assuming the radiation pattern is fixed (i.e. we are dealing with a given speaker) then there are a number of ways to address the problem. One way to correct the problem is by adding room treatment to absorb the "excess" energy radiated by the speaker. IMO this would be preferably to changing the on axis response, but for other reason (WAF) this might not be possible. Another is to alter the on axis response so that the power response is as desired, or should I say so that the reverberant field is as desired. That is fine if you listen in the reverberant field. But if you sit closer to your speakers this may not be such a good idea. And the thing is, the more lively the room, the bigger the problem.
The last way is to design a speaker with power response that, at least, behaves in a monotonic manor. While a step in the right direction, as speaker designers we all have to recognize that the best we can to is shoot for a design that will hopefully sound good is a variety of rooms with parameters (such as RT60) within a limited range.
[Edit]
By the way, if you look at the bottom of the web page I references you will see a plot of the in room response which is an indication of the reverberant field, of the NaO II. Also notice that the room RT60 is presented as well.
Old 3rd September 2010, 01:13 PM   #28
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I believe one of the strong points in small diameter full range loudspeakers that make them desirable for voices and tone despite their huge dynamic shortages, its their natural progression in power response. Geometrical wave launch coherence its their other obvious merit.
*That experience from little FR speakers reinforces the desire for a coherent & naturally drooping power response in bigger multi way systems.
Old 3rd September 2010, 01:37 PM   #29
StigErik's Avatar
Which concert hall then?
Personally I think the whole idea of using a live event as reference for reproduced sound is flawed, if not totally wrong.
Music recorded in stereo will never sound like a live event. Decca (and others) realized that in the beginning of Stereo back in the 50's. Stereo was a new medium, different from the theater and concert hall. It would have to be different, and it could also be better in many aspects than "the real thing". Recorded music is produced to sound great on a pair for speakers, not to mimic a live event.
Some may argue that "purist" recordings with a single stereo mic-pair is close to the real event. Its not. In such recording they also seek a mic position and orchestra placement in the hall for a "best" reproduction through speakers, with the mic pair located in positions impossible to sit in for an hall audience, like 4-5 meters above the floor.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 3rd September 2010, 01:42 PM   #30
Salas's Avatar
''Because I like it'' it would be much closer when we are asked why this and that in most home use designs IMHO.
DIY Shelf Stereo System? form109 Solid State 32 14th October 2010 06:32 AM
PA System Stereo or Mono 96tahoe PA Systems 8 5th April 2008 12:33 AM
Tuning a stereo system pityocamptes Car Audio 15 11th November 2007 01:31 PM
Stereo system with Subwoofer, How to do it? py Everything Else 5 13th January 2005 08:25 AM
Page generated in 0.14583 seconds (76.37% PHP - 23.63% MySQL) with 11 queries
