Old 7th September 2010, 01:58 PM   #41
opc is offline opc  Canada
opc's Avatar
Hi Dabbler,
You might find some of this to be of interest:
10" MTM with NeoPro5i Ribbon - Build Thread
I tested two of the drivers you're interested in, namely the TD10M and the 10NW64. The TD10M was a clear winner thanks to the poor cooling system on the 10NW64.
There are a bunch of measurements for both drivers spread throughout the thread.
Owen
Old 7th September 2010, 02:17 PM   #42
dabbler is offline dabbler  Australia
Originally Posted by doug20 View Post
I do not think there is a 3rd party measurement of the 10" but the TD12M exists and maybe you can start with that as a ref point.
AE Speakers TD12M - drivervault
Thanks Doug, apparently the TD12M does not have the breakup problem of the TD10M. The distortion graphs look nice over 80hz.
You are going to measure the drivers yourself, right?
I was only planning to measure the frequency response then use DCX2496 to fiddle with the crossover point.
Distortion measurements? wouldn't even know where to start.
Old 7th September 2010, 02:18 PM   #43
Owen, thanks, ill start wading through that thread now...
Old 7th September 2010, 02:26 PM   #44
doug20 is offline doug20  United States
Thats cool, Im a big fan of XOs with the DCX but still you need to have something in room to know what is going on. A notebook or PC with $150 measurement equipment (soundcard/calibrated mic) with free demo version of ARTA will go a long way to helping you tweak with the DCX.
Old 7th September 2010, 02:37 PM   #45
I have calibrated mic / sound card and REW for the in room measurements.
Old 7th September 2010, 02:56 PM   #46
Thanks, I will follow your build. I have extra CDs/HPR122i waveguides sitting around for future projects.
Old 7th September 2010, 03:00 PM   #47
Originally Posted by opc View Post
Hi Dabbler,
Owen
Owen, Im halfway through the thread, just a quick question: The 2.5khz breakup appears in your measurements of the TD10M. Is it audible on the 2K crossover you use?
Old 9th September 2010, 05:12 AM   #48
Just got the shipping quote for the TD10M's...
Using them over any of the B&C options is going DOUBLE the cost of the project. Are they doubley as good? Hmmm, suddenly that dip at 200hz on the 10NW64 ain't looking so bad!
Old 9th September 2010, 08:06 AM   #49
Im using B&C 10PS26 in a MLTL box. They sound wonderful. Very dynamic and "alive". Very high resolution. I like to cross them around 1,8 - 2,0 Khz.
We live in a horizontal world, why use vertical topologies???
Old 9th September 2010, 02:34 PM   #50
Nice work Circlomanen. The 10PS26 may be the ones I go with, nice smooth response to 2K and high efficiency. Should be easy enough to work with.
Ive emailed Al from USSpeaker about the finish quality of his DDS waveguides. If he confirms they are OK, ill take them.
Critique my 8" Pro Audio Woofer 8" Waveguide / Compression Driver Plans gibbed Multi-Way 21 9th March 2011 09:55 PM
10" coax - need opinions muresan_c_dan Multi-Way 2 8th August 2010 08:21 AM
Horn-loading the "new breed" of pro sound 6.5-8'' drivers Swedish Chef Multi-Way 61 28th April 2006 02:01 AM
Dayton pro 18" woofer w/4" VC rcavictim Multi-Way 8 27th November 2004 04:32 AM
partsexpress 10" pro series woofer Ilianh Multi-Way 0 4th April 2003 03:27 AM
Page generated in 0.12546 seconds (81.14% PHP - 18.86% MySQL) with 11 queries
