Found some older speakers...
Old 3rd July 2003, 06:29 PM   #1
swirv is offline swirv
swirv's Avatar
Send a message via AIM to swirv
Default Found some older speakers...
A pal of mine gave me the gutts and the speakers from an old Zenith HiFi. I do not know the model or date it was made. Unfortunatly no info is on the parts I have. The speakers are marked however. They consist of a 10" paper cone driver with 49-1221 on the back. There is also a horn tweeter marked 'foster' 49-1166. I think this just like the Foster/Fostex 40-1166.
The question is: What do I do with these things? I have no info on them exept what I can measure with my DMM. The 10's are 16ohm and the tweeter....uh...I forgot what the tweetet measured. The crossover was just a cap and resistor on the tweet with the 10 run fullrange.
They are in GREAT condition. The thing had a TT and an 8-track, so it is old. The speakers though, look brand new exept for a few little rust spots on the basket of the 10".
I will post pics as soon as I can get a hold of a digicam.
Any help would be cool.
Old 5th July 2003, 08:29 PM   #2
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Hehe, I get tons of these old console units, often the ones from just when transistors came out. The speakers are always like new because they never made amplifiers big enough to even barely drive them. I find that these speakers are usualy very nice and sound good for their age especially.
Has anybody else had experience with old speakers from radios and consoles?
I also found it that often 10" drivers were used in these consoles. What's up with that? Why never 8" or 12"?
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 8th July 2003, 07:42 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: Found some older speakers...
Originally posted by swirv
Zenith ... 10" paper cone driver with 49-1221 on the back. There is also a horn tweeter marked 'foster' 49-1166. ... 10's are 16ohm and the tweeter
16 ohm... are they alnico. Are they anything like these 49-1240. There may also be a number on them that gives away the manufacturer. The pictured ones are Rolas (and are quite lovely).
The Foster horn is also quite nice. The 1166 is one of the shorter ones -- were they mounted with a blue styrofoam spacer? There are some of these and relatives on my BD-Pipes page.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th July 2003, 07:43 AM   #4
frugal-phile(tm)
planet10's Avatar
And the Foster tweeter.
dave
Old 8th July 2003, 07:45 AM   #5
frugal-phile(tm)
planet10's Avatar
Some of those consoles have "gold" in them... please don't chuck em without salvaging the guts -- particularily the tube ones. You still in Alberni?
dave
Old 8th July 2003, 08:50 AM   #6
Duo's Avatar
Yes, I understand what you mean by "gold." Every one of these units I see going to the dump I try and take home. The drivers and guts out of them are often very nice. I have made some impressive speakers out of these units.
The tube consoles I usually try to keep working in original condition though. For example, I have a very very sweet Grundig floor console radio in perfect condition. The sound this radio produces is phenominal, full class A and those weird European speakers that are like 14" by 8" or something like that. I keep the unit in top condition and polish the cabinet frequently to keep any dust or foreign matter from settling on it.
So far, I've salvaged the guts out of every unit I have ever gotten before tossing the case. Some of the recievers in them turn into nice component size units when built into individual boxes. The speakers I remove and build into new enclosures. I can make a very nice system out of the guts of a console!
Old 13th July 2003, 05:39 AM   #7
swirv's Avatar
Dave,
The 10" speakers have what appears to be the same basket as the ones in your picture however, mine have a ceramic magnet and no dust cap. They have a fabric dust 'screen' over the pole piece.
Do you have any sugestions for these drivers? Dipoles? Horns? TL?
Any sugestions as to a direction to take would help. I have little experiance with drivers like these, and I see that you have played with quite a few.
thanks
Chris
Old 13th July 2003, 07:25 AM   #8
frugal-phile(tm)
planet10's Avatar
All the ceramic magnet ones i have seen have been 8 ohms, so i'm guessing yours are 1st gen ceramic then (as you get newer the drivers in this series seem to get less robust). Still a very sweet driver.
The ones i've seen all came in Zenith Allegro cabinats and with the sucky BR box they dont sound all too great. Take the back off and they open right up.
I plan on putting mine in some sort of quarterwave enclosure -- which one depends on how the T/S turn out. They also aren't too bad in an open baffle (as above).
Any numbers beside the 49-1221?
dave
Old 13th July 2003, 07:27 AM   #9
frugal-phile(tm)
planet10's Avatar
And here is another, prettier, version of the driver.
dave
Old 13th July 2003, 07:29 AM   #10
frugal-phile(tm)
planet10's Avatar
There are 8" versions of these too... less at the bottom, more at the top.
dave
Found some older speakers...Hide this!Advertise here!
How do DIY drivers compare to those found in commercial speakers? JayH3 Multi-Way 139 23rd March 2013 05:10 AM
Older Focal speakers mitchyz250f Multi-Way 24 14th July 2009 12:14 AM
Need help with older DEI amp whoya2350 Car Audio 21 6th April 2009 03:22 PM
Just found some speakers on ebay... not too sure what to make of it... SkinnyBoy The Lounge 2 21st December 2003 06:44 PM
Copyright ©1999-2017 diyAudio
