SB acoustics MidBass polarity .....
Old 24th August 2010, 04:59 AM   #1
juliopr is offline juliopr  Puerto Rico
Default SB acoustics MidBass polarity .....
Hello everyone.
I have a pair of SB Acoustics 6 inch midbass drivers with a wide and a narrow terminal on its back with no polarity signing or mark. Can anyone throw som light on this? Other than the 9v batt test?
Thanks.
Old 24th August 2010, 07:20 AM   #2
chris661 is offline chris661  United Kingdom
chris661's Avatar
9v battery test unless you can tell us which model they are, so someone else may be able to tell you.
My work: www.grimshawaudio.com
Old 24th August 2010, 08:31 AM   #3
rabbitz is online now rabbitz  Australia
rabbitz's Avatar
The larger terminal is +ve. Have a look at the plastic piece under the terminals as it's marked + & -.... look between the terminal and the mounting bracket on the basket.
No longer DIY active
Old 24th August 2010, 01:33 PM   #4
Thanks guys. I unscrewed the terminal strip and there were the markings hidden. The wider blade is the + terminal.
SB acoustics MidBass polarity .....Hide this!Advertise here!
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 01:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 01:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 11:30 PM
SB Acoustics vs Seas Prestige Audiodidakt Multi-Way 1 1st April 2008 04:14 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 09:15 AM
