#21 | |
Rgs, JLH
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way! |
#22 | |
Hello,
As for the latest version of Marco Henry's "La Grande castine", the 300-3000Hz frequency range reproduced thorugh the largest round horn is (most probably) mounted on a 2" B&C compression drivers. see: High Efficiency Speaker Asylum - RE: La Grande Castine - Jmmlc - July 01, 2010 at 09:07:32 On the previous version a Radian 950 was used. Best regards from Paris, France Jean-Michel Le Cléac'h Quote:
#23 |
Going back to Lynn's comment, I had a discussion with Radian some years back where they suggested a "shim" (spacer) between the diaphragm mounting ring and the body of the driver to provide a bit of extra Xmax type distance for the diaphragm. So that it would not slap the phase plug.
My assumption was that perhaps Lynn was thinking that below resonance the diaphragm would become unloaded and therefore hit the phaseplug? In a typical horn the diaphragm (I think this is correct) will be loaded down to the point where the horn ceases to work - usually a function of the mouth freq/size. That will tend to keep the diaphragm in check, loaded, BUT this isn't going to work at high SPLs, as in a PA/SR situation, running lower than resonance. So for that application operating below the resonance is probably not going to be a good idea. Also I was thinking that the "Q" of the resonance is part of the picture perhaps? Higher Q diaphragm/driver combinations might be more likely to run out of headroom below the peak? Getting rid of input below the lowest useful horn frequency is important because then the diaphragm becomes unloaded and wheeeee it has nothing but the surround (suspension) to control it. Thus high slope xovers in SR/PA use. Also, a lot of these diaphragm designs are "stiffness" controlled by the way the surround is created out of the aluminum - there is simply a maximum that it can move, and then no more, and it starts to get non-linear near the maximum. Some of the diaphragms are phenolic/cloth half round, and these are less likely to have this effect. But the standard JBL/ALTEC type surround is pretty stiff and self limiting... which is "good" for a high SPL SR/PA application I would expect. Contrast this with the WE555a which was rated down to 75Hz.! (but not at the same max SPL as the more "modern" drivers) So, in home hi-fi use at frequencies below the rated limit and with slopes less than the rated slope, one has to de-rate the max power and so the max SPL appropriately. The good part is that ~126dbSPL levels are not what most of us are going for in our applications. Most of the average playing level in home use is more like >30dB down from PA/SR use. That buys us a lot of flexibility that the PA/SR folks do not enjoy. _-_-bear
_-_-bear http://www.bearlabs.com ...live within ~60mi of Albany NY? contact me! -- Last edited by bear; 6th September 2010 at 03:26 PM. |
#24 | |
For ultimate performance compression drivers that require "deep pockets" see Products - http://www.goto-unit.com WHG |
#25 |
hi guys, thinking about building a Sato horn, any chance that a JBL 2445, 2446 able to do 150~200hz on that horn?
cheers |
#26 | |
Not enough clearance between the phase plug and diaphragm for this low of a [F3(hp)] even at 24 dB/Oct. Use an Community M4: http://www.communitypro.com/files/li...ts/M4_SPEC.pdf or See the JBL paper: http://www.jblpro.com/catalog/suppor...=201&doctype=3 or See GoTo Unit as well: Goto unit - Audio Voice Acoustics Regards WHG |
#27 | |
2.) I had it high passed at 100Hz 24dB/Oct. 3.) They were tractrix horns with 4" throats to match the driver. 4.) They did not have honk or nasal tone. 5.) Being loud and filling a room is entirely different than having correct tonal balance. 6.) I built 11 slit radial phasing plugs for the cone drivers and they far exceeded the "performance" of the M4. I followed the guidelines in Clifford Henricksen's AES paper preprint no. 1328 (F-5) 7.) The so called phasing plug of the M4 is crude at best. 8.) I tried the original diaphragms, the sandwich foam/aluminum ones, and the carbon fiber ones - they all stink. 9.) The M4 is a piece of garbage and anyone that thinks otherwise needs their hearing checked. Why are there so many available cheaply on the used market if they are so good? 10.) Goto is over priced and not a realistic option for the large majority of people.
#28 |
Following your assertions 1.)-10.) are my responses > ... :
Regards, WHG 1.) I had it low passed at 800Hz 12dB/Oct. > Too low. 1,000-2,000 Hz is recommended by the manufacturer. No wonder it sounded bad; the signal feed it is not even the bandwidth of a telephone. 2.) I had it high passed at 100Hz 24dB/Oct. >Too low, the minimum is 200 Hz. Nasty output is expected under your conditions. 3.) They were tractrix horns with 4" throats to match the driver. > Did the slopes of the driver and horn match at the throat connection point? 4.) They did not have honk or nasal tone. > The tractrix curve is a near optimal contour for a horn; So, none is expected. The bell is fully formed as well; so, back-waves are minimized. 5.) Being loud and filling a room is entirely different than having correct tonal balance. > The tonal balance is a measure of the marriage with other drivers outside the too-narrow, 100-800 Hz, range imposed; so it is a non-issue here. This driver is capable of filling a stadium with clean voice band signal. At lower in-room levels, its output signal is pristine. The artifacts of a too-small horn will change this. 6.) I built 11 slit radial phasing plugs for the cone drivers and they far exceeded the "performance" of the M4. I followed the guidelines in Clifford Henricksen's AES paper preprint no. 1328 (F-5) > Bob Smiths circumferential slit phase plug design is superior [1] & [2]. It addresses the cancellation of radial modes that must occur when [Sd]>[St]. The claim here is suspect as well. 7.) The so called phasing plug of the M4 is crude at best. >On what basis is in inferior? Because it is not a radial type? 8.) I tried the original diaphragms, the sandwich foam/aluminum ones, and the carbon fiber ones - they all stink. >For the former design, I agree. For the later design, you are not using the driver properly. The "stink" is coming from elswhere! 9.) The M4 is a piece of garbage and anyone that thinks otherwise needs their hearing checked. Why are there so many available cheaply on the used market if they are so good? >The assertion is patently fallacious. You do not have the information necessary to make the claim. How many are in the field? vs. How many used are for sale? In this case, one man's garbage may well be another's treasure. 10.) Goto is over priced and not a realistic option for the large majority of people. > False! There are very few large format compression drivers from which to choose. So it remains the last, all be it, the most expensive alternative. Overpriced, no! High priced yes! The cost of the materials used here are expensive, they include Permendur pole pieces, Alnico magnets, and Beryllium diaphragms. So, some some naivety is being revealed here. I Note that there is no comment for the JBL paper I referenced. New References: [1] File: ASAJ025-0305.PDF Title: An Investigation of the Air Chamber of Horn Type Loudspeakers Author: Bob H. Smith Publication: ASA-J, Vol. 25, No. 2, Pg. 305-312, Mar-1953 Affiliation: Division of Electrical Engineering, University of California URL: Cookies Required Abstract (1): The front air chamber design is treated as a boundary value problem which yields a solution of the wave equation for the general case in which the horn throat enters the air chamber in a circumferentially symmetrical manner. Abstract (2): The following specific cases are analyzed: (1) the case in which the horn throat enters the air chamber by means of a single orifice, (2) the horn throat enters the air chamber by means of a single annulus of radius [r] and width [w], and (3) the horn throat enters the air chamber in [m] annuli of radii [r1],[r2],...[rm] and widths [w1],[w2],...[wm]. Abstract (3): The analysis reveals that the radial perturbations caused by the horn throat excites higher order modes. At the resonant frequencies of these modes the horn throat pressure becomes zero and the loudspeaker does not radiate. By suitable choice of annulus radii and widths the first [m] modes may be suppressed and the corresponding nulls in the output pressure eliminated. [2] File: AESJ057-0771.PDF Title: New Methodology for the Acoustic Design of Compression Driver Phase Plugs with Concentric Annular Channels Author: Mark Dodd Affiliation: GP Acoustics, Ltd., Maidstone, UK Author: Jack Oclee-Brown Affiliation: GP Acoustics, Ltd., Maidstone, UK Publication: AES-J, Vol. 57, No. 10 pp. 771-787 (Oct-2009) URL: AES E-Library: New Methodology for the Acoustic Design of Compression Driver Phase Plugs with Concentric Annular Channels Abstract: Compression drivers couple a radiating diaphragm to a horn throat of smaller area, resulting in high efficiency. Commonly a phase plug is used to control the transition from diaphragm to horn in order to improve the high-frequency performance. In this paper a new design method for the positioning of annular phase plug channels is presented in order to improve the driver response. |
#29 |
No experiences yet, but this new 5"er could fit the bill.
http://www.ciare.com/pdf/catalogo/PM135ND.PDF |
#30 | |
do you know the reason, they switched the Radian for a B & C ? |
| Wood cone speakers for Frugal-horn or other DIY | EmergencyDpt | Full Range | 24 | 3rd April 2009 11:03 AM |
| Single Driver Horn Base Port from Frugal Horn | EmergencyDpt | Swap Meet | 0 | 26th October 2008 02:24 AM |
| JBL 2482 phenolics OR horn loaded cone driver for low-mids? | pk | Multi-Way | 11 | 26th March 2008 07:48 AM |
| AH Njoe Tjoeb CD player, valve Compatibility | emperor | Digital Source | 0 | 13th November 2007 06:15 PM |
| Phase plug for cone driver in mid-bass horn design? | mefistofelez | Multi-Way | 2 | 18th October 2003 08:59 PM |
| Page generated in 0.17956 seconds (88.56% PHP - 11.44% MySQL) with 11 queries |
