#11 |
Powered by Google Docs
..and also of interest: http://vincent.brient.free.fr/round_horns.htm I think this one would be better than the Radian for the mid-band (and cost a lot less too): http://www.critesspeakers.com/D405.pdf Note that it is NOT the "ti" version.
perspective is everything Last edited by ScottG; 23rd August 2010 at 08:20 PM. |
#12 |
nice find Scott, that Selenium..
#13 |
I think distortion is complete NO issue for compression drivers, used below Fs.
Audio Asylum Thread Printer These results are important as well as interesting since the insignificance of Level was not anticipated. The fact that nonlinear distortion in a compression driver is not a significant subjective parameter is quite enlightening and useful. Prior to this study, the exact opposite was believed to be true; that nonlinear distortion was a major problem in compression drivers. Regardless of any previously held notions about the auditory importance of nonlinear distortion in compression drivers, what the data is saying must be accepted - nonlinear distortion in a compression driver is simply not a factor to its sound quality. This conclusion is in agreement with other recent publications on nonlinear distortion in horn/waveguide compression driver subsystems that conclude that virtually all of the distortion in these subsystems is the result of the waveguide itself.[2] The data shown here is substantial support for this position-certainly from a subjective perspective. One significant result from this study is that there is no reason to consider any aspect of compression driver design from a nonlinear distortion perspective. In fact, one could argue that these results indicate that distortion could be substantially increased, in order to save money or tradeoff other aspects of the design for distortion (like sensitivity), without having a negative impact on the sound quality of the device. Without access to the results presented in this report, the audio community would certainly have taken exception to this conclusion, and would likely object most strenuously. http://www.gedlee.com/downloads/AES_subjective.pdf there are even 1" compression drivers used to cover down to 300hz. See the examples with the Sato horns. links to webpages with pictures and descriptions of Audio Systems with hornspeakers - Page 59 - Audio Voice Acoustics Jean Michel also confirms positive results : Jean Michel on LeCleac'h horns The best sounding low mid compression drivers I used to listen were: 1) Goto 2) WE555 (I have the Alnico French modification by LMT) 2) Onken 3) Yamaha JA6681 (I have 2 pairs of them) 4) TAD TD2001 (yes, a bit modified and on the Sato horn above 250Hz) 5) Vitavox S2 6) Philips I have not made any measurements. Bass lowpass i use now 300hz/24db. The Radian has remained in the lower midrange channel. I would love to try a GOTO UNIT SG-555P GOTO UNIT SG-555P????????????16???? - Yahoo!?????? an other interesting alternative is the Vitavox GP1, with a large suspension, similar to the WE555a Vitavox - Page 2 - Audio Voice Acoustics that driver should aloud to play quit low in a apropriate horn |
#14 |
Nice pictures in websites. Bring this Eminence PSD:3006-8 2" Titanium Driver 8 Ohm | Parts-Express.com to the bag.
#15 |
Just saw these posts now, thanks much for the ideas.
#16 |
Radian 950. impedance in ph2380 (2380 clone(?)) and free air
flesh flash flush |
#17 |
http://www.radianaudio.com/component.../1245_1225.pdf
1245 diaphragm
flesh flash flush |
#18 |
What about this?:
MONACOR INTERNATIONAL:Product detail page I'm using Selenium D405 in dedicated 90x40 Selenium CD horn and the best sound I've got is for 500Hz@24dBLR up. Also tried 360Hz and 400Hz @18dB/24dBLR but were not so good into my system ( http://forum.audiofil.ro/index.php?topic=524.0 ). Hope it helps. Last edited by DorinD; 5th September 2010 at 11:29 AM. |
#19 |
Hello Dorin,
Nice system you have over there. Although I knew it for some time, I wasn't aware you are using the D405. Nice.. |
#20 |
The compression driver I prefer to use to cover this range, is the Community M4. See
http://www.communitypro.com/files/li...ts/M4_SPEC.pdf. However, the cost of this unit will bust your driver budget. Other viable candidates operated at slightly higher c/o frequencies [fh] will as well. Alternatively, you can design and build your own phase plug and use a direct radiating low [Qts] driver. The horn to properly load these drivers is quite large. Horn cut-off [fc] should be approximately octave below the -3db point [fh] of the high pass filter used. Horn length < [fh]/[vs]/4 and mouth perimeter < [fh]/[vs] is contraindicated here. If the horn is of minimum recommended dimensions, then a steep sloped (=> 24/db/oct) high pass filter should be used to protect the driver as it becomes unloaded. Unlike direct radiating drivers, the proximity of the phasing plug imposes displacement limitations on diaphragm movement long before its suspension limits are met. |
| Wood cone speakers for Frugal-horn or other DIY | EmergencyDpt | Full Range | 24 | 3rd April 2009 11:03 AM |
| Single Driver Horn Base Port from Frugal Horn | EmergencyDpt | Swap Meet | 0 | 26th October 2008 02:24 AM |
| JBL 2482 phenolics OR horn loaded cone driver for low-mids? | pk | Multi-Way | 11 | 26th March 2008 07:48 AM |
| AH Njoe Tjoeb CD player, valve Compatibility | emperor | Digital Source | 0 | 13th November 2007 06:15 PM |
| Phase plug for cone driver in mid-bass horn design? | mefistofelez | Multi-Way | 2 | 18th October 2003 08:59 PM |
| Page generated in 0.12633 seconds (79.26% PHP - 20.74% MySQL) with 11 queries |
