Rock Wool Equivalent Volume
Old 16th August 2010, 03:36 PM   #1
jlsem is offline jlsem  United States
jlsem's Avatar
Default Rock Wool Equivalent Volume
Anyone have an idea how much I will have to adjust the volume of my speaker box to compensate for adding some of this product?
Roxul Acoustical Fire Batts Mineral Wool 2 inch Case of 6
Thanks,
John
Old 16th August 2010, 04:22 PM   #2
Cro maniac is offline Cro maniac  Croatia
Cro maniac's Avatar
Maybe this could be of some help:
Make A Small Box Act Like A Larger One With Polyester Fiberfill By TOM NOUSAINE
-Dubravko
Old 16th August 2010, 05:17 PM   #3
jlsem's Avatar
I'm using the rock wool to damp the inner walls of a bass cabinet. I'm assuming that the relationship of the equivalent volume between this batting and air isn't 1:1.
John
Old 16th August 2010, 06:20 PM   #4
Top Shelf is offline Top Shelf  Canada
Top Shelf's Avatar
Take the rock wool and squish it with your thumb and finger down
As thin as it will go then take that compressed thickness say it's
a 1/2" and times that by the square footage of all the roxul in the
cab and that is the approx. volume.
NO REST FOR THE WOOFER! 🔊😈
Old 17th August 2010, 04:30 AM   #5
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
From one of the Richard Small's papers on loudspeaker design (the "Closed Box" paper I believe) he gives an estimate of about +15% volume for firberglass in a fully stuffed box. Starting with this estimate I always took dacron batting to be about 10% and long fible wool to be in the 20% range. Of course these are estimates.
Just lining the walls will not make a difference in the apparent box volume. The mechinism at work here is the stuffing absorbs energy from the rear radiation of the driver in the box. This effectively increases the apparent compliance of the air in the box making the box "look" bigger to the driver.
Rodd Yamashita
Rock Wool Equivalent VolumeHide this!Advertise here!
pi speaker kits for rock and hard rock? ta_nhra02 Multi-Way 13 26th January 2010 04:11 AM
WTB: Wool or Acousta-Stuf Jimmy154 Swap Meet 0 24th August 2008 12:33 AM
long haired wool vitalstates Full Range 23 7th February 2007 05:09 PM
wool vs Dacron/BAF in TL Henkjan Full Range 6 12th September 2006 06:15 AM
Glass wool. Is it dangerous? sachi Multi-Way 15 20th March 2005 02:31 AM
