OMNI Gallery
OMNI Gallery
Old 13th August 2010, 08:31 PM   #21
gainphile is offline gainphile  Australia
gainphile's Avatar
Default Bolzano Villetri
UltimateAVmag.com: CES 2006 Show Report
http://gainphile.blogspot.com
Old 13th August 2010, 08:34 PM   #22
gainphile's Avatar
Default Duevel Planets
Old 13th August 2010, 08:35 PM   #23
gainphile's Avatar
Default Ohm Micro-Walsh Tall SE
StereoTimes - Commentary
"Incredibly large sweet spot with a layered 3-D soundstage"
Old 13th August 2010, 08:40 PM   #24
gainphile's Avatar
Default "Anthonyspeaker" ?
Home Theater photos and Home Theater Pictures - Home theater idea Picture
Old 13th August 2010, 09:44 PM   #25
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
OMNI Gallery
And if you go WAY back...
Zenith "Circle of Sound"
Old 13th August 2010, 10:17 PM   #26
flat*music is offline flat*music
thanks Chis661, but as I have a copuple of t amp boards hanging around I was thinking of using them in place of building up the pluto amps, but still using the filters and crossover network from the pluto design.
Old 14th August 2010, 04:52 PM   #27
gainphile's Avatar
Default IKEA Omni ?
ORION/PLUTO Users Group • View topic - Building a sleek woofer basket
Old 16th November 2011, 10:38 PM   #28
gainphile's Avatar
Default The Demokrit
Demokrit
Check out the measurements. The "most omni" I've seen.
This sonogram is showing nothing... simply because it's 360 dispersion to 20khz!
At 12khz!! :
Old 16th November 2011, 10:46 PM   #29
rob g is offline rob g
Active 3 way loudspeaker system based on external dsp crossover/filters/eq/correction etc. - YouTube
Old 17th November 2011, 05:43 AM   #30
6.283 is offline 6.283  Germany
Hi Andi,
thanks for lifting me into the Omni Gallery.
Originally Posted by gainphile View Post
At 12khz!!
No, at any frequency Arta typically displays !
2Pi-online.de
OMNI GalleryHide this!Advertise here!
Omni-dipole tinitus Full Range 3 11th February 2013 07:53 AM
A 2-way Omni experiment bwaslo Multi-Way 29 18th July 2010 02:31 AM
paging OMNI from Rossford Ohio.. grantnsw Multi-Way 0 17th June 2008 09:20 AM
omni directional speakers dvsound Introductions 4 25th November 2007 03:21 PM
Omni-fast hm Full Range 0 29th July 2007 12:27 PM
