Old 7th August 2010, 06:36 PM   #1
twest820's Avatar
Default four inch driver with good efficiency and low Rms/high Qms?
Looking for a small driver similar to the SB12NRX but with an efficiency of 90dB SPL 1W/m or better versus the SB12's ~84dB. And pulling a total blank, though I've found a couple nice five inchers and several sixes. Any suggestions? Application is the mid in a four way nude dipole, target frequency range is 500Hz to 2kHz---I've been planning to use the BG Neo8 but the fairly good front/back wave symmetry John K is getting out of the 10F in the Nao Note has prompted me to check for other options.
Old 8th August 2010, 05:46 AM   #2
GOWA is offline GOWA  Canada
GOWA's Avatar
I'm not sure if this meets your criteria but Zaph just tested the Scan Speak Discovery 10F/4424G00 and it looks quite nice.
Old 8th August 2010, 04:10 PM   #3
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Agree with GOWA, Try use the HR program when comparing the drivers:
b
Old 8th August 2010, 09:33 PM   #4
twest820's Avatar
Since John K was using it the 10F was one of the first drivers I checked. However the sensitivity of both variants is a bit under 86.5dB 1W/m. Agree the 8424G00's a stronger candidate than the SB12 based on sensitivity and Rms, but the 10F's unusually low Sd is a bit of a problem---this is visible in bjorno's HR comparison above 150Hz. I agree with Zaph the 10F's more of a three inch driver.
Looking over ScanSpeak's lineup again I suppose I should add the 15M/4624G00 to the list of fivers.
Old 8th August 2010, 10:07 PM   #5
ScottG is offline ScottG  United States
Fostex has a few, 126E and 127E,
ALTEC CF208-8A,
3" driver:
Faital Pro 3FE20.
I'm betting all have some problems with their surrounds, at least when compared to the Scan 10F.
I can vouch for the *sound* of the Altec driver (..but I haven't had access to measurement equipment for some time now). The build quality *looks* fairly decent as well. Again though, I can almost guarantee that it has some issues with the surround.
I'd bet that the Faital Pro's sound is the *least* likely to have problems with it's surround of the grouping, AND I'd bet the subjective impression is *very* detailed - more so that even the Scan 10F.
perspective is everything
Old 8th August 2010, 10:55 PM   #6
twest820's Avatar
The FE126E and FE127E are discontinued, replaced by the FE126En which has 0.35mm xmax. The FF125K is probably a stronger option, particularly as it lacks the FE whizzer but, like 0.35mm, its 0.15mm xmax is certainly painful for dipole use. Not having any luck digging up the Altec, but the Faital Pro 5FE120 is probably the best set of tradeoffs so far. Thanks. (If I can figure out how to get my hands on one, anyway. )
Yup; the motor, too. Just looking for something with good dynamics and where a small amp actually has enough power to drive the thing. I'll cross to the woofer in the four way before the mid ends up needing too much excursion, but it does need enough xmax to hit 0.5mm or so with good THD/IMD.
Old 9th August 2010, 02:29 AM   #7
frugal-phile(tm)
planet10's Avatar
If you don't have a need for a whack of them i have FE127 & FE126. Inuendo from a German distrib (who heard it from the factory) is that the xMax is the same on the FE126En as on the FE126e, but was incorrectly stated in the earlier driver.
FF125 is also discontinued. Rumour (from a different distrib) is that we could see a variation on the FF line but with specs closer to the FExx7 series than the FExx6 series. That doesn't help your project thou.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th August 2010, 02:57 AM   #8
This driver does look promising, a very compact dedicated midrange with nice sensitivity and a nice price. I found a vendor with a quick search asking US$25 for these. Kind of a goofy mounting flange though, it suggests reverse-mounting for sure.
Old 9th August 2010, 05:44 AM   #9
Not having any luck digging up the Altec..
I got the part number wrong on the Altec..
ALTEC CF404-8A Speakers
http://www.altecpro.com/pdfs/CF404_SS.PDF
Again, sounds pretty good - but probably measures pretty poor. (..I'd purchased it for a radial mid use, and it's pretty good for that.)
Old 10th August 2010, 12:19 AM   #10
twest820's Avatar
Thanks for offering. So far the 5FE120's still in the lead.
Lack of T/S parameters in the datasheet's usually a warning sign. For the price I'd expect decent but unexceptional with the trafo bypassed.
High efficiency 12 inch midrange - recommendations? hasselbaink Multi-Way 12 26th August 2009 09:00 AM
Low wattage, high efficiency, high quality? Nordic Multi-Way 5 4th September 2005 11:12 PM
High Qms bass driver Ap Multi-Way 3 3rd June 2004 08:07 PM
12" driver with big Xmax,low Fs, & high efficiency? WolfmanX Multi-Way 18 26th November 2002 11:10 PM
efficiency of high power toroids at low load? capslock Parts 8 24th April 2002 10:26 PM
Page generated in 0.12136 seconds (76.93% PHP - 23.07% MySQL) with 11 queries
