Hi everybody!
I have a matched pair of Fountek neocd3 ribbon tweeters. I want to use them in a 2 way config, with some 5" or 6" midbass. Wich one would you recommend me and why? I have a pair of Polk LSI7 midbass. They seems to be a custom design made by Peerless, but the truth is that i can´t get a sound that fits with the ribbon tweeter. They aren´t that good. I´ve tried to cross them at 3khz, witouth a good result. They have a terrible peak in the middle zone. I didn´t tried to cut the midbass around 2.4-2.5khz and the tweeter at 3khz, should i try it or should i keep looking for another midbass? I´m sorry if there is any mistake on my spelling, my english is not perfect. |
#2 |
LB8 from EMSpeaker looks interesting
#3 |
Seas ER18RNX - very very good value and excellent sound.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles |
#4 |
Hey, i´m sorry but i forget that i´ve made the same question some months ago.
The truth is that i been trying to make a good crosspoint for my drivers without success. I will keep trying to make a good crosspoint for them, and if it´s impossible, i will look for some new midbass. |
#5 |
How are you approaching this design? Do you have any means of measuring the frequency response of the respective drivers?
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#6 |
Peerless 830883, best value for money, check out the distortion profile on Zaph's website
(but the SEAS driver is very close too...)
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#7 |
I've only seen that tweeter used in a 3 way or very small 2 ways. see : Fostex FE126E + MiniStatements HTGuide Forum - Lineup Series Build Thread (F4, D4, D44, R4, R44) / sreten.
#8 |
I am currently using this Scanspeak of the "Discovery" range :
Scan Speak Discovery 18W8434G00 I fully agree with the comments made on it at the Zaph Audio Blog. |
#9 | |
The only thing i know, is that the midbass is used in Polk LSI7/LSI9, and they used it with a crosspoint of 2.4khz with a 18db slope. But i´ve tried today this crosspoint with an active filter and they sounded equal than crossed at 3khz. And well, i have t/s parameters of tweeter, i bought them brand new in Europe. Do you think that it would be worth to measure the speakers? |
#10 |
Location: latitude 40.8510 longitude -96.7592 altitude 362 meters
I'll suggest that the Neo3CD be crossed no lower than 3.5K. Most 6" or even 5" drivers will not be able to reach that high off axis, so a design using them would likely exhibit compromised power response. Using those tweeters, I'm thinking a 3 way design with a 4" mid or perhaps a 2" dome mid might be a better choice.
The use of CAD crossover software (such as Jeff Bagby's PCD) will significantly improve your chances of a successful design. Curt
Curt's Speaker Design Works |
| please recommend a 8 inch midbass | rhythmdiy | Multi-Way | 3 | 17th October 2007 01:06 PM |
| What would you recommend? | bjackson | Chip Amps | 0 | 21st November 2005 04:17 PM |
| What would you recommend? | desert00rat | Subwoofers | 10 | 15th April 2005 10:49 AM |
| which midbass would be better? | kan3 | Multi-Way | 0 | 6th January 2004 04:01 AM |
| Can you recommend me. | jleaman | Solid State | 1 | 26th February 2003 10:50 PM |
| Page generated in 0.11750 seconds (80.56% PHP - 19.44% MySQL) with 10 queries |
