I have finally commited to a design for my first open baffle speaker and started a new thread as a continuation of this one here.
Its a tri-amped 3 way open baffle with BG neo3 , 8 inch mid (possibly an old visaton B200) and dual 8 inch woofers in a U-frame. Initial concept pics are attached. Rudolf previously recommended the Visaton WS 25 E which has very good specs for open baffle use. I have been looking at the WS 20 E as possible 8 inch option. It has the same efficiency, x-max and higher Q of 1.14 but uses a polycone rather than paper. At A$40 each I believe it is good value. Will also consider automotive subs as suggested by Matevana. I will be using a DCX2496 and will EQ as much as possible to boost the bass response. Baffle will be 23-25cm wide and approx 1m high. Not sure where to start in terms of sizing the U baffle so please fire any suggestions at me. I would like to have the option of sealing the u-baffle if i need better low end response in the future as in John K's NAO. Due to the narrow baffle, I think the mid will need eq to get down to the desired 120-150hz before the woofers take over. I have modelled this in edge which shows atleast 10db boost is necessary to avoid a large dip at the crossover point. Thoughts? |
#2 |
Erm ... make your baffle wider e.g. say 12"/30cm to 15"/38cm and use a 0.6 ratio driver horizontal offset to smooth the response. I cannot see your arrangement working down to ~ 135Hz c/o point without some serious max SPL issues. /Sreten.
#3 |
you could mount small hinged "wings" on each side of woofers
mid rolls off with more than caused by baffle, theres also dipole related rolloff I dont know, how much power does it take, this mid small voice coil, may not take much Eq maybe place a good 10" just below mid, and raise xo point and make bottom woofers low crossed subs, and in H-frame instead |
#4 |
Before I cave in to increasing the baffle width over 250mm, lets say I can accept a 3db dip at the crossover point of 150hz. Edge says I need 4db of EQ to achieve this (see attachement). Does this effectively mean I am reducing my driver efficiency by 4db? If so i dont see this as a problem depending on the mid used.
I have also considered using the eminence beta 8a which has 95db sensitivity. Will I have a chance here or should I abandon this crazy anorexic open baffle crusade and start obeying the laws of physics? |
#5 | |
but not so easy to find with good sensitivity Alpha-6A might work too and if Emminence, combined with Alpha-8A or 10A using very simple filters and active subs if loud SPL, maybe with active low cut high pass on lower Alpha I would consider something like Hypex dsp plate amp |
#6 |
Its not just the frequency response, its also max cone excursion related. /Sreten.
#7 |
Hi dabbler,
I have recently finished my ...hmm...like fifth open baffle speakers and I used B&G Neo3 as tweeter (as dipole no back), I selected FF125K as mid (it matches sensitivity ~93dB with tweeter), so the advice from tinitus if great one, use smaller mid, and I placed it on top of 15" closed box woofer...I know, compromise in bass, not an open baffle, but its a good compromise, I am affraid in your arrangemnt you will not reach low enough. I have not posted the pictures on the web yet, but I will. This is the best speaker I made so far over 20 years (it made me sell the Lowthers), the hight and mids are the best I have heard...and you can load it with power too. I biamp the system, thats another plus, I equalize the system, so its flat 30-20k. Very happy with the result. |
#8 |
Hi Dabbler,
8" on 30cm baffle will work fine both SPL and off-axis polar response. I have used the standard bunnings 29cm planks with great result. Then you are able to use 2x 10" woofers instead of 8". http://gainphile.blogspot.com/2009/1...implicity.html For the U-Frame I have used again, a standard 24cm planks from Bunnings. It's great SPL-wise but I prefer no u-frame. I tried wings before but they create more issues than what being solved. Knowing that you go active with the system I can see you'd get a successful result either way. 1m will be too short. Perhaps 115cm so that the tweeter axis is slightly above the ear. But maybe you have low couch Edit: btw. If you use 8" drivers, then in fact you can stack more of them ! I had such thought sometimes ago
http://gainphile.blogspot.com Last edited by gainphile; 6th August 2010 at 06:36 PM. |
#9 |
I am not sure why a smaller mid will be necessary. Maybe to get a higher xover point with the neo3?
Gainphile, I didnt realise bunnings sold those 29cm planks. That sounds like an easy option! Are these in pine? |
#10 |
On second thought, 8 inch mid is beaming above 1.5khz and neo3 xover point is around 2.5khz. So I have a problem here.
| My first Open Baffle Speaker | audiojoy | Multi-Way | 197 | 2nd September 2010 10:29 PM |
| Best 4 inch driver for open baffle help ? | bigaudioscotto | Full Range | 23 | 22nd July 2010 08:27 PM |
| Cast frame Audio Nirvana 12 inch in open baffle | jamikl | Multi-Way | 2 | 8th June 2009 11:10 AM |
| Page generated in 0.10728 seconds (81.80% PHP - 18.20% MySQL) with 11 queries |
