My 8-inch open baffle speaker
Old 6th August 2010, 02:42 AM   #1
dabbler is offline dabbler
Default My 8-inch open baffle speaker
I have finally commited to a design for my first open baffle speaker and started a new thread as a continuation of this one here.
Its a tri-amped 3 way open baffle with BG neo3 , 8 inch mid (possibly an old visaton B200) and dual 8 inch woofers in a U-frame. Initial concept pics are attached.
Rudolf previously recommended the Visaton WS 25 E which has very good specs for open baffle use. I have been looking at the WS 20 E as possible 8 inch option. It has the same efficiency, x-max and higher Q of 1.14 but uses a polycone rather than paper. At A$40 each I believe it is good value. Will also consider automotive subs as suggested by Matevana. I will be using a DCX2496 and will EQ as much as possible to boost the bass response.
Baffle will be 23-25cm wide and approx 1m high. Not sure where to start in terms of sizing the U baffle so please fire any suggestions at me. I would like to have the option of sealing the u-baffle if i need better low end response in the future as in John K's NAO.
Due to the narrow baffle, I think the mid will need eq to get down to the desired 120-150hz before the woofers take over. I have modelled this in edge which shows atleast 10db boost is necessary to avoid a large dip at the crossover point.
Thoughts?
Old 6th August 2010, 03:08 AM   #2
R.I.P.
Erm ... make your baffle wider e.g. say 12"/30cm to 15"/38cm and use a 0.6 ratio
driver horizontal offset to smooth the response. I cannot see your arrangement
working down to ~ 135Hz c/o point without some serious max SPL issues.
/Sreten.
Old 6th August 2010, 03:45 AM   #3
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
you could mount small hinged "wings" on each side of woofers
mid rolls off with more than caused by baffle, theres also dipole related rolloff
I dont know, how much power does it take, this mid
small voice coil, may not take much Eq
maybe place a good 10" just below mid, and raise xo point
and make bottom woofers low crossed subs, and in H-frame instead
sometimes we know very little, and sometimes we know too much
Old 6th August 2010, 04:42 AM   #4
Before I cave in to increasing the baffle width over 250mm, lets say I can accept a 3db dip at the crossover point of 150hz. Edge says I need 4db of EQ to achieve this (see attachement). Does this effectively mean I am reducing my driver efficiency by 4db? If so i dont see this as a problem depending on the mid used.
I have also considered using the eminence beta 8a which has 95db sensitivity. Will I have a chance here or should I abandon this crazy anorexic open baffle crusade and start obeying the laws of physics?
Old 6th August 2010, 05:31 AM   #5
I would use a much smaller mid
but not so easy to find with good sensitivity
Alpha-6A might work too
and if Emminence, combined with Alpha-8A or 10A
using very simple filters
and active subs
if loud SPL, maybe with active low cut high pass on lower Alpha
I would consider something like Hypex dsp plate amp
Old 6th August 2010, 02:03 PM   #6
R.I.P.
Its not just the frequency response, its also max cone excursion related.
/Sreten.
Old 6th August 2010, 03:07 PM   #7
adason is offline adason  United States
adason's Avatar
Hi dabbler,
I have recently finished my ...hmm...like fifth open baffle speakers and I used B&G Neo3 as tweeter (as dipole no back), I selected FF125K as mid (it matches sensitivity ~93dB with tweeter), so the advice from tinitus if great one, use smaller mid, and I placed it on top of 15" closed box woofer...I know, compromise in bass, not an open baffle, but its a good compromise, I am affraid in your arrangemnt you will not reach low enough.
I have not posted the pictures on the web yet, but I will. This is the best speaker I made so far over 20 years (it made me sell the Lowthers), the hight and mids are the best I have heard...and you can load it with power too. I biamp the system, thats another plus, I equalize the system, so its flat 30-20k. Very happy with the result.
Old 6th August 2010, 07:27 PM   #8
gainphile is offline gainphile  Australia
gainphile's Avatar
Hi Dabbler,
8" on 30cm baffle will work fine both SPL and off-axis polar response.
I have used the standard bunnings 29cm planks with great result. Then you are able to use 2x 10" woofers instead of 8".
http://gainphile.blogspot.com/2009/1...implicity.html
For the U-Frame I have used again, a standard 24cm planks from Bunnings. It's great SPL-wise but I prefer no u-frame.
I tried wings before but they create more issues than what being solved.
Knowing that you go active with the system I can see you'd get a successful result either way.
1m will be too short. Perhaps 115cm so that the tweeter axis is slightly above the ear. But maybe you have low couch
Edit:
btw. If you use 8" drivers, then in fact you can stack more of them ! I had such thought sometimes ago
Old 8th August 2010, 01:10 PM   #9
I am not sure why a smaller mid will be necessary. Maybe to get a higher xover point with the neo3?
Gainphile, I didnt realise bunnings sold those 29cm planks. That sounds like an easy option! Are these in pine?
Old 8th August 2010, 01:28 PM   #10
On second thought, 8 inch mid is beaming above 1.5khz and neo3 xover point is around 2.5khz. So I have a problem here.
My 8-inch open baffle speakerHide this!Advertise here!
My first Open Baffle Speaker audiojoy Multi-Way 197 2nd September 2010 11:29 PM
Best 4 inch driver for open baffle help ? bigaudioscotto Full Range 23 22nd July 2010 09:27 PM
Cast frame Audio Nirvana 12 inch in open baffle jamikl Multi-Way 2 8th June 2009 12:10 PM
