I have a quick question.. I have a folder horn W Bin cabinet that I am going to load with a JBL 2241 woofer, the Fs value of the woofer is 35Hz, should I aim to tune the ports in my box to 35Hz or is it acceptable to tune the ports to 40Hz as well/ i'm just not sure if the Fs value of the woofer has to match that of the cabinet.
Thanks Glenn |
#2 | |
Port tuning is related to the drivers resonance in the box, not free air, in box its always higher, you need to know Vas, Fs, QTS and Vbox for the proper value. Having said that just tuning to 40Hz is not a terrible idea, low tunings are actually quite flexible regarding boxes, unlike optimum higher frequency ones. /Sreten.
#3 |
My question is, the JBL 2241H woofer I am putting in these cabinets has a Fs value of 35Hz on the T/S specs. Now I'm not sure should I tune the speaker box to this value as well?
#4 |
Hi, No, that is simply not the way it works as I said,
/Sreten.
#5 |
Thats a folded horn and horns are complicated, so get Hornresp (Download) and enter all the data.
Then you can see both the frequencyresponse and the excursion, to see what tuning gives the best compromise for your box+speaker combination. |
| Help with tuning a speaker enclosure | retroman | Multi-Way | 9 | 17th May 2009 11:36 PM |
| Speaker Cabinet | InfinityPWS | Multi-Way | 2 | 13th January 2006 02:11 PM |
| Rebuilding Speaker Cabinet | Oddity | Multi-Way | 0 | 11th February 2005 03:19 AM |
| Speaker tuning and RTA's | RyanC | Multi-Way | 0 | 21st May 2004 05:33 PM |
| speaker tuning | ViPER | Multi-Way | 9 | 6th January 2004 07:16 AM |
| Page generated in 0.07596 seconds (74.50% PHP - 25.50% MySQL) with 10 queries |
