Old 2nd August 2010, 08:20 PM   #1
Default cannot figure out crossover
i have a crossover here that i cut years and years ago (probably ten years ago) and i cannot determine what wire goes to the mid, tweet, and woofer.
my best guess was that the red wire must be for the tweeter because it is after the capacitor.. but after fiddling around with the remaining wires, all sets perform as both the midrange and the woofer going well down to 25hz and up to 4khz.
obviously i am not doing something right and i need some help.
nature.. time.. and patience are the three great healers
Old 2nd August 2010, 08:57 PM   #2
holdent is offline holdent  Canada
The photo doesn't show the detail of the wiring layout well enough, Can you draw a diagram or at least take a better shot with all the wires laying flat? Do you have any of the specifications for the inductors and the capacitors?
I count 6 wires (clockwise blue, red, brown, black, green, white), 2 inductors and a capacitor. This appears to be a two-way (not 3 way) crossover. One large inductor, and a capacitor and smaller inductor suggests that this is a 1st-order cross for the woofer and a 2nd-order cross for the the tweeter.
Old 2nd August 2010, 09:49 PM   #3
Pano is offline Pano  United States
Pano's Avatar
Looks to me like:
Red: tweeter +
Brown: Tweeter -
Black: Input -
Blue: Input +
Green: Woofer +
White: I dunno
Unless this was a series crossover. Naw, probably not.
Take the Speaker Voltage Test!
Old 2nd August 2010, 10:25 PM   #4
the inputs are the two silver tabs where everything is soldered.
on the other side there are spring terminals.
i can see all the wires laying flat already.
maybe your monitor needs some brightness adjustment.
(the photo is a little dark on the brown and black, but things are still intelligable)
its a stock KLH 3-way crossover from the rear of a 12 inch woofer cabinet.
somebody wants to use the crossovers for their vehicle and i dont remember how the wires went, nor can i figure out the 18? different possibilities of wiring the speakers as i originally thought.
i'll take the pic down and edit it using a photo editor and brighten the picture then reupload it to satisfy your need.
i dont have the values of the inductors.. but if i look up my model number, i might be able to find some crossover points if there is anything on the web posted.
Old 3rd August 2010, 01:53 AM   #5
prickears's Avatar
I remember pulling apart a technics speaker, (3 way 10 inch paper woofer/paper cone tweeter + 'super' tweeter) a while ago, it had some kind of tweeter that was wired directly to the amp, it was very small and weighed next to nothing, and had a silver cone. Could it be that we are looking at a LP, PB crossover that had a similar tweeter wired direct?
Making stuff 'idiot proof', Just breeds more effective idiots.
Old 3rd August 2010, 05:29 AM   #6
I think what Pano said, but the mid is wired across the cap???
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 3rd August 2010, 09:56 AM   #7
someone asked for a drawing / diagram of the layout so to see things better.
i have drawn one and posted:
am i wrong to think that the..
capacitor is for the tweeter
smaller inductor is for the top end of the midrange
bigger inductor is for the low end of midrange and top end of woofer
maybe i should unglue these components and re-solder a circuit that i can understand
Old 3rd August 2010, 09:59 AM   #8
also.. i remember the tweeters, they didnt have any capacitor glued onto them.
just two tab terminals only.
Old 3rd August 2010, 12:25 PM   #9
Couzld it be that the mid wa run full-range ? Then the large coil would be for the woofer and the highpass (cap & coil) for the tweeter and the blue one would go to the midrange.
In this case there must have been a very robust midrange (probably a small woofer) - was it ?
Charles
Old 3rd August 2010, 01:42 PM   #10
Pano's Avatar
Oops! I missed that it was a 3 way in the OP.
Uh, Now I'm now sure what goes where. :-/
Can Anyone figure this? duderduderini Tubes / Valves 8 6th April 2008 01:27 PM
Trying to figure out what a part is in an amplifier. Beat_Dominator Parts 16 22nd July 2007 10:02 AM
Can't figure out Zaph's design... cjnordquist Multi-Way 12 29th July 2005 11:45 PM
help me figure this out please xdissent Solid State 7 23rd November 2003 08:57 AM
Page generated in 0.10829 seconds (75.34% PHP - 24.66% MySQL) with 11 queries
