Why many designs call for not changing baffle size ?
How does the crossover takes the Baffle size into consideration ? Is it OK to change baffle Height as long as I dont change internal volume ? |
#2 |
Baffle step?
It's ok, to change height, but it's not ok to change width and distance of the speakers to the upper edge. reins |
#3 | |
Good designs incorporate "baffle step compensation" and this compensation is mainly related for typical speakers to baffle width (the smaller dimension). Generally you can change baffle height but keep the width the same, make speakers taller but less deep, or vice versa shorter and deeper. Its also best to maintain geometry relative to the top edge. /Sreten.. |
| Open Baffle Size for Pioneer B20 | repeddler | Full Range | 14 | 15th February 2010 05:24 PM |
| Baffle Size for Driver Testing | rgodin | Multi-Way | 8 | 14th February 2010 04:38 PM |
| Minimum size for open baffle driver? | Javachip | Multi-Way | 2 | 28th June 2007 12:06 PM |
| Open Baffle - What's Your Image Size ? | Will | Planars & Exotics | 3 | 12th May 2006 05:15 AM |
| Size and shape of infinite baffle | j.burtt | Multi-Way | 22 | 27th September 2005 01:26 AM |
| Page generated in 0.07015 seconds (72.23% PHP - 27.77% MySQL) with 10 queries |
