Old 1st July 2003, 01:11 AM   #21
frugal-phile(tm)
planet10's Avatar
Originally posted by sonicfury
Something with a small chamber , size something like 1/2 or 1/3 VAS and the small chamber being ... connected to the secondary chamber (which is much bigger) via a variovent.
That describes the Dynaco A35/A40
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st July 2003, 11:09 AM   #22
Yeah northcreek ... i remember - right.
It was this guy from northcreek
Thank you !!!
Old 1st July 2003, 11:23 AM   #23
Found it!
Multichamber Aperiodic Progressive Damping
Pete
Old 1st July 2003, 11:46 AM   #24
7V is offline 7V  United Kingdom
7V's Avatar
Originally posted by Pete Mazz
Found it!
Looks interesting, Pete. Is that the animal that you were describing some time back, kelticwizard?
Steve
Old 1st July 2003, 12:36 PM   #25
7V:
Yes, that is the one.
That paper certainly clears up the confusion I had, as well I am sure that many others had, about whether an aperiodic design had one chamber or two.
Much thanks, SonicFury and Mazz.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 1st July 2003, 08:00 PM   #26
7V's Avatar
I seem to remember that some time ago Speaker Builder ran a series of designs where the driver was mounted in a box which was ported into a larger rear enclosure where the size wasn't too critical - cupboard, car boot (trunk), etc.
Maybe this concept could be tuned with a variovent type of arrangement (or a sock in the tube - I've still got some spare socks that I haven't yet filled with sand).
Steve
Old 19th February 2005, 04:01 AM   #27
Default problematic driver
Hi everione, i have read all posts and exchanges mails with some speakers gurus like troels gravesen, and the variovent appears t be the only solution for some "decent bass". the driver parameters are these:
Z: 8 Ohms
Re : 5,5 Ohms
Fr: 46 Hz
Qa: 4,2
Qe: 0,7
Qt: 0,6
Mms: 0,034371 Kg
Cms: 3,48E-04 New/m
Bl: 8,84 Wb/m
Sd: 0,035968 m2
Vas: 6,31E-02 m3
Rms: 2,37 Kg/s
the simulation programs like WinISD and BassBoxPro 6 says an ideal enclosure about 100 L or more. a 45-50 liter cb is mandatory.
Someone can help with the folowing?
How many variovents?
size of each?
how much material inside each one?
material compressed or loose?
placing in enclosure?
thanks, gaston
Old 19th February 2005, 06:48 PM   #28
GM is offline GM  United States
GM's Avatar
For my records, what brand/model driver is this and are these published or measured specs? Pe, Le, Xmax?
Don't know what the Variovent's DF is, but doing a sim in MJK's PORTED WS to determine a DIY golden ratio 1.75ft^3 (gross) cab variant:
L = 23.4"
W/D = 8.93" x 14.16"
driver down 10.82"
stuffing density = 0.2lbs/ft^3, or ~5.6oz of polyfil
vent = 2" dia x 4" long stuffed with ~5.6oz of polyfil (contain on each side with a mesh screen)
vent down 22"
No real bass output to speak of though with an aneochoic ~60Hz F3, this cab is just too small.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 20th February 2005, 02:04 PM   #29
The driver is an Audifiel 10bx, made in Argentina. I'm studying there. Is the best affordable driver I can get. The audio world here is so so prehistoric, that drivers like scan-speak, vifa, morel and so on does not exist!. the bestyou can get are car drivers from pioneer, some alpine and they are really expensive for a student, so the 10bx is the only choice. See it at www.audifiel.com
The specs are not published, since the driver does not have then on it's box. So i wrote to the manufacturers and they sent them las week. The other parameters says "1" in the exel file they sent, that's why i did not post them. So Troels suggested the variovents as the only solution to get nice bass from the 10bx, and that's why i'm here.
Thanks again, i will try a 42 L cab with a home made variovent on the back, tuned by ear. Some suggestions and advices will be WELL received.
gaston
Old 20th February 2005, 06:49 PM   #30
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
The 8HX looks pretty cool as a full range. Is it expensive?
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Different "Q" in sealed boxes Moondog55 Subwoofers 19 11th June 2009 01:44 AM
AUDAX speaker, with "special" sealed cabinet arcturus Multi-Way 1 27th September 2005 07:56 PM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.10055 seconds (82.64% PHP - 17.36% MySQL) with 11 queries
