Old 4th September 2008, 04:56 PM   #111
badman is offline badman  United States
Custom Title
badman's Avatar
No easy answers tomato.
There's no 3dB loss of sealed WRT ported. That's a fallacy, the ported alignments add output around the tuning, but that's not 3dB added to the reference efficiency which is how it's often described.
How it influences the box size depends upon the driver/box combo, there's no simplification that can be applied.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 4th September 2008, 06:40 PM   #112
Oh great to know, i thought that the sealed configuration makes a loss of 3dB of the "factory" effeciency of the driver
So if the effeciency of a driver is 97dB (on correct specs) it will stay 97dB in a sealed enclosure
In fact if i understand you it is the ported enclosure that improve the output only on a frequency range
Well there is still physical laws as O_cool's reference to Hoffmann's iron law that i discover not that far
i mean what should i expect ?
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Different "Q" in sealed boxes Moondog55 Subwoofers 19 11th June 2009 01:44 AM
AUDAX speaker, with "special" sealed cabinet arcturus Multi-Way 1 27th September 2005 07:56 PM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.20690 seconds (30.04% PHP - 69.96% MySQL) with 11 queries
