it's a general practice to cover the entire enclosure on the inside to reduce the resonance. but why does the port always get left out of the treatment? the port itself is made out of plastic, which i should think can be excited easily sonically. and when it's a flared port, such as mine, the flange adds extra inches of diameter from the port that is left filled with void when the hole in the enclosure is cut out to accommodate the flare. i should think that the reasonable thing to do is to fill the reverse side of the flare to to address the void- with such molding material as concrete, which i shall be using. also cover the port itself with some felt or other acoustic absorbents as it has been done to the rest of the enclosure that the port will be residing in. of course im a novice builder and this is purely speculation based on my version of common sense. so i'd appreciate lots of inputs, thank you very much.
#2 |
Maybe. Engineering is all about sweating the details and knowing which details matter. It is more important to get the length and diameter right than worrying about the plastic port resonating. If it bothers you, attach some damping material to the outside of plastic pipe.
#3 |
My guess is that there are no forces on the port which would cause it to resonate.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#4 |
If you're using a cylindrical tube it's going to be pretty stiff anyway.
#5 |
Funny transmission of sound pressure from inside the cabinet at higher frequencies than the intended bandwidth of the port is a lot bigger problem than the port material moving, and anything you do to reduce this transmission except at quite high frequencies is a tradeoff against passband performance.
#6 |
I also guess the port material resonating itself being no
serious problem with BR. Nevertheless a passive radiator might be the more "noble" BR implementation, addressing problems like noise and (organ pipe) port resonances. |
| bd pipes port material? | porkchop61 | Full Range | 30 | 27th May 2009 07:50 PM |
| Single Port Vent Better than Dual Port? | Daveis | Multi-Way | 18 | 15th July 2007 05:12 AM |
| To port or not to port? Newbie with newly built mains | starquake | Multi-Way | 1 | 18th December 2004 12:51 PM |
| flexible plastic tubing as port material?? | Lligior | Multi-Way | 3 | 6th September 2003 06:50 AM |
| Page generated in 0.10263 seconds (64.17% PHP - 35.83% MySQL) with 10 queries |
