Old 26th July 2010, 05:50 AM   #1
makokoy is offline makokoy  United States
Default Need help Cabinet design/dimesion for SEAS 8"
I need help what cabinet dimension for this speaker below.
I just want simple bookshelf. SEAS 8"
http://www.seas.no/images/stories/vi...282_p21rex.pdf
thank you
Old 26th July 2010, 07:55 AM   #2
Inductor's Avatar
Strange. It says Fs=33Hz and measured is 60Hz.
Maybe that's the 20L box, and go's down with time (a little).
Anyway, you gonna need the rest of the speaker...
This is not a full range.
Old 26th July 2010, 08:01 PM   #3
GOWA is offline GOWA  Canada
GOWA's Avatar
makokoy, could you be a little more vague?
Old 26th July 2010, 10:48 PM   #4
unibox gives me 55L tuned to 37Hz for an F3 of 35; probably a bit big for a bookshelf...
35L with the same tuning will give an F3 of 43Hz, I wouldn't go smaller than that... a 6" is probably a better bet for a bookshelf...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 26th July 2010, 11:43 PM   #5
Inductor's Avatar
Is good to know more details (like planned construction, BSC? and xover frequency).
Last edited by Inductor; 26th July 2010 at 11:45 PM. Reason: new or existent project
Old 27th July 2010, 12:16 AM   #6
GOWA's Avatar
The Seas CA22RNX (H1288) will give you a sealed box of 28 liters (1.0cf); f3 of 60Hz
Old 27th July 2010, 05:52 AM   #7
sorry for my limited english and lack of info I thought designing cabinet based only on woofer.The 8" Seas currently in my RSL CG8 and sounds much better from the original woofer but lack of base . I'm thinking of building box with intended design for 8" P21REX seas using the RSL CG tweeter and X-over this might improve the bass if the cabinet is design for this woofer? do you think I can hear difference? if so,what would be the cabinet dimension. some problem I can't find specs of my tweeter and xover
I know lot of you guys have more knowledge in building speaker cabinet.
thanks
Old 28th July 2010, 12:15 AM   #8
Inductor's Avatar
The value for components are all there, only missing is value for the second resistor, not visible.
Tweeter Seas h0456/25tf
Old 28th July 2010, 03:41 AM   #9
Makokoy, what are the internal dimensions of the boxes you already have?
Old 28th July 2010, 04:08 AM   #10
the inside dimension maybe 9x14.5x11 and the outside is H 15.5"x W 10" x D 12"
Problems with "shallow" cabinet design? mfellman Construction Tips 2 12th April 2010 04:38 PM
Can anyone suggest a cabinet design for the Audio Nirvana 8" FR? Toppsy Full Range 7 6th November 2009 12:25 PM
cabinet design help for 5 1/4" subwoofer gychang Subwoofers 30 4th July 2007 10:17 PM
Newbie question re: "Proper" cabinet design Ken C Multi-Way 5 8th June 2004 07:14 PM
Audax HT170JL28 6-1/2" cabinet design? JeremyD Multi-Way 0 15th February 2004 03:06 PM
Page generated in 0.10063 seconds (80.03% PHP - 19.97% MySQL) with 11 queries
