Old 25th July 2010, 04:51 PM   #1
DIFORCE is offline DIFORCE  Australia
Default Speaker makes a scratching sound
Hi , just wanna confirm with you guys about how absolutely retarded I am
So the other day I wanted to chamfer the inside of the woofer's hole in the back with an 1\2 inch chamfer .... The thing is there was bits of aluminium flying around everywhere and sticking to the speakers magnet ... No problem i though to myself , easy to clean... right ? wrong.
Thing is a didnt put any protective sponge or somthing inside the hole so the bits wont go inside the woofer or anywhere near the voice coil while im chamfering... so they did , and now when i push the cone with my finger the speaker makes a scratching and buzzing sound when I move it up and down , the speaker is the Seas ER18RNX 7 inch woofer .., Obviously small bits of metal are in between the magnet and the voice coil.
My question is simple Do I have to buy new speakers for my project ? or is there any way to clean it up ? I tried vacuuming it with my vacuum cleaner but it doesn't come off .... maybe some oil spray or air pressure spray ? help ?
Old 25th July 2010, 05:30 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
Cut around the dustcap, leaving it attached with a small flap (I hold an exacto flat against the cone - so half the handle thickness above the existing glue joint) then use sticky tape to fish out the filings - these are iron, not aluminum. Aluminum wouldn't stick to the magnet. Then glue the dustcap back down when you are sure there is no more rubbing.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 25th July 2010, 05:59 PM   #3
Will try that !!! thank you very much
Old 25th July 2010, 11:22 PM   #4
Tried it , But it is impossible to fish out the little bits of iron that are just between the VC and the magnet they are too small ... and wont stick as they are magneted hard to the .. magnet.
Any way to reverse magnet polarity or somthing ? or use a stronger magnet ? or maybe i could just cut through the surround ... remove the membrane entirely clean it up and glue everything back ?
Old 26th July 2010, 02:00 AM   #5
Ron E's Avatar
Well, it was worth a try. Magnets can be demagnetized and remagnetized, but it takes special equipment. If you start getting into major disassembly of glued parts, your FR probably won't look so nice when you are done. I wonder if you can buy a recone kit for the driver from the mfg? If you can pull the whole thing off, it might be easier to clean it out, and then insert a new diaphragm assembly. But if that doesn't work you may be getting close to the cost of new drivers.
Old 26th July 2010, 02:04 AM   #6
I did get close to the cost of new drivers , oh well. Might as well order the new U18RNX woofers and build the 2-way Idunn instead of mark K's ER18DXT ...
Speaker midwoofer scratching! please help! Toast_Master Multi-Way 10 24th September 2007 11:53 PM
yamaha amp scratching sound ihodiputah_510 Solid State 2 22nd April 2006 08:43 AM
With one makes more sound! destroyer X Solid State 43 8th June 2004 11:11 AM
What makes different speakers sound ... different? cuallito Multi-Way 16 14th April 2004 01:13 AM
What makes the most sound improvement? BlackDog Chip Amps 19 29th February 2004 07:56 PM
Page generated in 0.09057 seconds (74.78% PHP - 25.22% MySQL) with 10 queries
