Old 24th July 2010, 06:59 AM   #1
Default New Mid - Scan-Speak 15M/4624G
Is there anything to be excited about here? It looks like it's efficient and has a nice frequency response.
https://www.madisound.com/store/prod...oducts_id=8926
Old 6th September 2010, 01:56 PM   #2
otto88's Avatar
  • NRSC* Fibre Glass Cone * Non-Resonant-Suspension-Coupling, a Scan-Speak Patent
  • Phase Plug for Improved Phase Linearity
  • Very Low damping Coated Foam Surround
  • Aluminum Ring in Magnet for Improved Impedance Control and Lower Distortion
  • High Sensitivity 92,5 dB
and only $62
sounds like a definite short lister, Thanks!
Old 6th September 2010, 02:01 PM   #3
chlorofille's Avatar
it looks too good to be true LoL
wonder if anyone has incorporated it in a project...
Old 6th September 2010, 03:26 PM   #4
5th element's Avatar
If it performs as well as the 10F it would be something of a class leader.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 6th September 2010, 04:36 PM   #5
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
Very keen to see this driver used, mabye tested by Zaph too. On paper it looks brilliant, such a smooth response!
Looks like we started threads on the same day!
New Scan Speak midrange driver
Old 7th September 2010, 04:44 AM   #6
Ared is offline Ared  Hungary
Aren't the Scan discovery drivers the new name for old Vifa designs being manufactured in Denmark again? It would be kind of strange if this was a new driver..
Old 8th September 2010, 01:38 PM   #7
Some of them are, but Scan has also been releasing brand new drivers under that line too. The 10F is like getting Scan speak engineering at a fraction of the cost. The same with the Peerless HDS tweeter, which as I understand was always manufactured by Scan speak anyway.
Old 9th September 2010, 08:32 AM   #8
rinx is offline rinx  Estonia
Was it?
First they were manufactured by Peerless owned By Tymphany. Tymphany were owner of Scan Speak, but 2009 some investors bought Tymphany out and Scan Speak become again Danish company. Tymphany were the sales divison. So the case should be this way, that producer were de facto Scan Speak and Tymphany sold them under brand name Peerless (HDS product line (old 810921)?
Old 9th September 2010, 01:46 PM   #9
From what I understand, yes.
Old 27th February 2012, 03:35 AM   #10
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
It may use some old tooling from previous Vifa lines, but, overall, it is a new driver - I've not seen any driver quite the same as this one.
A few things to note, that might not be noticed unless you look at the driver in your hand: very well vented behind the spider. Very nice cast frame with quite thin legs (won't have reflection issues). The cone is a thin fiberglass cone with a coating on the back (I presume to damp resonances) and the edge of the cone where it meets the surround has flat cuts - I presume this is the "Penta-Cut patented NRSC technology" from Vifa?
It does measure very smooth, and, anecdotally, I would say it has very low distortion through the midrange.
I like it, based on the one I got to test I will buy a couple more [enough for a pair of speakers + a spare in case they become unavailable later].
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Wich Scan Speak Bass/Mid Kal Multi-Way 5 16th November 2009 10:04 PM
FS: Pair of Scan-speak 18W/8531G-00 7" Revelator mid/woofer sholz64 Swap Meet 3 26th September 2008 08:39 AM
Scan Speak 15M Jed Multi-Way 27 23rd March 2007 07:45 AM
FS: Scan-Speak 25W/8562 woofers/MB Quart MBM 50 S Mid-Range/MB Quart MCD 19E Tweeters Ballylongford Swap Meet 0 1st August 2006 06:20 AM
Scan-Speak 15M/4531K00 Pair mp006ltk Swap Meet 1 24th October 2005 02:14 AM
Page generated in 0.11259 seconds (84.19% PHP - 15.81% MySQL) with 10 queries
