Would this woofer work well in a 2 way vented configuration?
If so what crossover/tweeter might be suggested as a start? These will be used inside my gazebo; powered with 50 wpc amp Thanks GW-6PC/8 Parameter Value Unit / Notes Effective Piston Area (Sd) 136.43 cm2 Free Air Resonance (Fs) 59.3 Hz DC Resistance (Re) 7.4 Ω Mechanical Q Factor (Qms) 6.306 Electrical Q Factor (Qes) 0.496 Total Q Factor (Qts) 0.460 Voice Coil Inductance (Le) 2.1 mH/milli-Henrys Equivalent Air Volume ( Vas) 7.6 Liters Moving Mass (Mms) 24.7 Grams/Mmd + air load mass Suspension Compliance (Cms) 292.581 μM/N/micro-Meters per Newton Force Factor (Bl) 11.688 Tm / Tesla-Meters Sensitivity (SPLref) 87.2 dB/Reference 8Ω/2.83Vrms X-Max 4.0 mm |
#2 |
Better for you to use a tested speaker (there are so many in this forum). I'm taking this from your question. It's possible to use that mid-woofer, Fs is high and other problems are, you have to design a xover. Look at the (similar) problem with mcmahon48.
| suitable woofer for TL | CharlieM | Planars & Exotics | 0 | 14th March 2008 10:03 PM |
| Bought a woofer, need help finding suitable enclosure | Simpleton | Subwoofers | 12 | 11th May 2007 02:42 PM |
| suitable 10" woofer and tweeter for this amp?... | lunchmoney | Multi-Way | 0 | 5th April 2005 07:28 PM |
| Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? | Layberinthius | Tubes / Valves | 0 | 11th March 2004 08:49 PM |
| Page generated in 0.05664 seconds (72.26% PHP - 27.74% MySQL) with 11 queries |
