Old 24th July 2010, 01:04 AM   #1
dfidler is offline dfidler  United Kingdom
dfidler's Avatar
Default Rules of Thumb for Enclosure Designs - Questions
Hi All,
First diy design is ongoing. It's on paper atm (and in 3D) but it's just the visuals; no measurements/projections attached to it yet as I simply lack that experience/knowledge right now.
What I'm looking for some fronts to satisfy the following requirements:
  • Ultra clear highs+mids; warm, bass.
  • Music tastes: I like everything 'cept country; cuz country ain't music. However, most of my listening is, atm, new age... though I go through phases where I like classical, rock, rap, etc. I'd rather have accuracy over boom though.
  • Good power handling; I'd like them to shake the house with HT too.
  • Room sizes will generally be wide but not very deep (usually 8-10' from listening position and 20' wide; see attachment to see my current flat)
  • Budget? Unknown. I'll start with a budget of 2500 pounds for drivers+electronics with the expectation that nothing ever comes in on budget, so closer to 4000 (in stages). I'm toying with getting some diamond tweeters in parts, but honestly, the more I save on the speakers, the more I'm allowed to spend on the amp.
  • It cannot have 6 sides; I hate boxes and so does the wife. I'm thinking of a curved back enclosure or other variety.
Because I've spent the last two years drooling over the 802Ds, I'm thinking of taking my inspiration from them; dual woofers (perhaps 8" or 10", balanced by the xo), mid in its own chamber, tweeter up top.
To this end, I have a few questions:
  1. What plays the biggest role in providing transparency to a loudspeaker? Cabinet shape? Driver quality? Volume of the the cabinet? Magic? Marketing?
  2. Does the shape of the enclosure affect the overall precision of the sound? ie - I've already been told that spherical and cylindrical enclosures offer the best sound for bass which leads me to think that this is because those shapes offer relatively uniform resistance under compression from the driver. (So I'm surprised that 99% of cabinets out there are boxes; especially in high end ones).
  3. (Assuming MDF construction) Does having the mids/highs in the same enclosure as the bass greatly effect their sound? What if they're in their own closed chamber in the same enclosure?
  4. Is there significant merit to completely segregating the highs/mids from the bass enclosure (and possibly even each other)?
  5. When you get to the higher end for woofers, does it really make a difference as to which one you buy (ignoring the cabinet requirements)?
Most of these questions are born from my lack of listening experience with hifi systems. I have the B&W 683s right now and they sound good to me but I really want more than what I've got. I want better clarity in both my highs and lows, wider sound stage, better transparency, etc. I want speakers that would cost me a bajillion pounds, commercially, for about a tenner.
Dave.
Old 26th July 2010, 10:57 PM   #2
1: driver selection, followed by box design and crossover design
2: depending on what you mean by 'precision', yes. Cylinders and spheres have advantages, but they also have pitfalls - what is good for outside the box can be the opposite on the inside.
3 & 4: Yes, generally mids should be in their own sealed enclosure to isolate them from the backwave of the woofer. Don't assume MDF construction.
5: Depends on where you cross over to the mid, but generally I'd say no -- others will probably disagree. Spend more money on good mids.
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 26th July 2010, 11:23 PM   #3
dfidler's Avatar
@PeteMck, thanks; could I ask you to clarify some points?
1: Transparency
a. re: Driver Selection - most important for transparency is the tweeter or the mid or, IYO, both play an equal role?
b. Box design - proper balance of internal volumes? internal chamber shape? external shape?
ie - obviously, the speaker shouldn't be inside of a tunnel (ie - recessed into the enclosure), but anything else?
2: By precision I meant that I'm more concerned with sound accuracy than SPL.
5: Spend more on good mids - awesome, thanks!
Old 26th July 2010, 11:53 PM   #4
dfidler's Avatar
note: it might also help to know where I'm coming from with these questions. Attached are some enclosure designs that I'm toying with.
I've discarded the read-diagonal woofer idea (while it looks awesome, it's really impractical so I might go for a horizontal rear mount instead but with a round enclosure, that means they'd be recessed into a cutout of the enclosure or mounted on a tube that protrudes out; also not ideal)
The third attachment, speaker2.png, is more where I'm heading. Vertically aligned drivers, mounted at the end of a cylinder (that floats in the overall enclosure on silicone lining; a design I came up with as a result of my "zero-vibration subwoofer question/thread). This frees up the front of the speaker for just the one tweeter and mid on the front.
These kinds of designs have spousal approval (though, she says, it's a bit big) but, aside from the fact that manufacturing it would be a nightmare, I'm not sure where this design (or any like it) falls down.
Note; The second pair of images show the size of the enclosure with 2x 12" subs (vertically mounted, firing opposite each other). I may shrink the overall enclosure by 15% and mount 2x10" subs... if I even stick with this overall theme.
Old 27th July 2010, 12:05 AM   #5
dfidler's Avatar
note: The technicians out there will say that this doesn't classify as a design yet because I haven't given any specifics on dimensions, volume, drivers, etc.
But at this stage, I'm only concerned with whether the overall direction that I'm taking with the enclosure is going to be bad for the clarity & transparency of my sound.
After all, if I put all of the work into these enclosures, I don't want a design flaw to make them sound like mud.
Old 27th July 2010, 12:33 AM   #6
Driver selection - the mid is by far the most important; if you can get the distortion profile if the driver it will help with selection. This is not published by manufacturers, google Zaph Audio for tests.
Box design - I prefer a semi-circular enclosure behind the mids, but the shape isn't the important thing, it's the damping of the panel resonances and internal standing waves. Obviously shape can help with this. Check out Troels Gravesen's site for plenty of interesting constructions
Old 27th July 2010, 12:43 AM   #7
dfidler's Avatar
@PeteMck - thanks for the links; I've spent about 2 mins on Troels site and it's knocked my socks off!
Old 29th July 2010, 07:15 PM   #8
buggers is offline buggers  United States
1. The crossover is the single most important part of the speaker. Everything else is secondary.
Any monkey can pick some cool looking drivers, build a really awesome looking box, and buy a ready made Xover, but it will most likely sound like crap. The Xover Is the speaker.
Old 29th July 2010, 07:29 PM   #9
frugal-phile(tm)
planet10's Avatar
In a sense. Everything is important.
Crossovers are evil. It is certainly the hardest to get to work decently. I avoid them completely as much as possible, and if i have to use one, put it where it is less an issue (really low or really high)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th July 2010, 07:53 PM   #10
At least you know, what you want.
Maybe you heard about the TEMPTATION FROM THE DARK SIDE ?
Thought about leaving the cabinet behind and build dipoles or hybrids ?
But anyhow, the position of the speakers shown in the room is not suited
for dipoles. It it is very problematic for any speaker i would guess.
What about throw..nghpmp.. hanging the screen over the door and placing
the speakers left and right from the door ?
Listening position could be in the direction where the sofa is right now,
but slightly forward.
Like positioned now, you cannot find any speaker in the world which performs
there as my educated guess.
Kind Regards
Oliver, RFZ believer (?)
www.dipol-audio.de
Fostex Enclosure Designs rcayot Full Range 4 27th December 2007 11:14 PM
Rules of thumb when designing a TMM 2.5 way Dave Bullet Multi-Way 2 16th March 2007 08:31 PM
Car Enclosure designs Raphael Shaw Car Audio 2 18th May 2005 07:20 PM
Bias Rules of Thumb?? Zero Cool Solid State 15 17th February 2005 10:08 PM
Are there rules of thumb for inrush current? leadbelly Parts 8 26th February 2004 01:50 PM
Page generated in 0.15357 seconds (77.25% PHP - 22.75% MySQL) with 11 queries
