I am assembling a pair of 2-way powered monitors. Stereo amp inside. I can go active x-over ($$$) each but was wondering about using passive components: putting the chokes on the woofer amp output, caps on the hi amp output.
As each amp would only "see" the signal passing through (same rational as bi-wiring) how would this compare to active split before the amps? Comment opinions and facts all welcome. |
#2 |
No advantage. Each amp would be operating full range, which means you lose most benefits of biamping. Plus, passive crossover components can be more expensive, and don't work as well as an equivalent DIY active crossover. A better use of two amps might be to bridge them, and use a conventional passive crossover. Although theory says that biamping should give about the same result, my gut thinks bridging will be louder.
| Passive mixer with powered preamp? | VanZea | Solid State | 4 | 4th May 2010 03:16 PM |
| Converting Active monitors to passive. Help! | Stereomaster | Multi-Way | 21 | 10th May 2009 07:17 PM |
| Powered monitors for home DJ application | Flames | Multi-Way | 9 | 14th February 2005 06:50 PM |
| Passive or Powered? | JRKO | Solid State | 13 | 13th August 2004 07:21 AM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
| Page generated in 0.07798 seconds (66.49% PHP - 33.51% MySQL) with 10 queries |
