ECM8000 - THD and IMD performance
Old 24th July 2010, 04:42 AM   #21
Reverberant is offline Reverberant  United States
Originally Posted by gedlee View Post
OK, I have a question: How is the THD of a mic measured? Surely its not a trivial task!
I figured you would know this better than I would.
For an absolute calibration you use a source with extremely harmonic low distortion such as an electrostatic actuator, pistonphone or (as IEC 60268 seems to imply) a very linear speaker at a low level. Another method specified by IEC (which only measures 2nd order distortion) is to measure two signals from two identical sources 80 Hz apart and compute the distortion that way.
I don't have any of those, so I'm going to assume that my ACO 7052 has essentially no distortion at relatively moderate levels (the mic is rated to 3% distortion at 150 dB), make a reference measurement with a source, use that distortion measurement as a baseline, measure the same source with the DUT, and then compute the difference. The problem is that I'm assuming you can't just subtract the difference, so my plan is to actually back out the raw 2nd/3rd/4th harmonic levels, compute the difference, and then recalculate the (hopefully) additional distortion level of the DUT.
Hopefully this will work.
Old 24th July 2010, 04:48 AM   #22
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by panomaniac View Post
On the original mic that it is tracked back to, I have no idea. On the others, it just seems to be compared to a reference mic.
Well that won't work. THD is not frequency response, comparisons like that aren't valid.
Earl Geddes Gedlee Website
Old 24th July 2010, 04:55 AM   #23
oldbar is offline oldbar  Australia
Here is a link of a EMM-13D082/H-P48/RM I have bought to do my speaker measurements if anyone is interested.
iSEMcon GmbH
Wolfgang seems very knowledageable.It will be interesting to see how he measures his mics etc
Old 24th July 2010, 02:05 PM   #24
Pano is online now Pano  United States
Pano's Avatar
And I'm not that interested in THD anyway. Much more useful would be a tracking of harmonics along the frequency scale, such as HOLMImpulse or STEPS does. That would really tell us something.
But at least from the info linked to in this thread, I'm not too worried about distortion as long as the SPL at the capsule is <100dB.
Take the Speaker Voltage Test!
Old 25th July 2010, 01:03 AM   #25
catapult is offline catapult
Earl, I don't think you're giving Herb enough credit for knowing what he's doing. Forget THD and look at the individual harmonics. They are indeed a 'frequency response' of dB vs. freq. If you assume that the reference mic's distortion is very low, most of the distortion it measures is due to the speaker generating the signal. It's relatively simple math to get from there to how much extra distortion the mic under test is contributing. Maybe not a perfect NIST test but good enough for our purposes.
Dennis H
Old 25th July 2010, 02:14 PM   #26
I think Earl was responding to panomaniac's comment about directly (implied) comparing the THD of the two mics, and he's right, you can't do that. Hence my plan to try to actually back out the raw harmonic levels and go from there. We'll see.
Earl is also right when he says that it's not a trivial task - B&K provides a lot of data with their individual mics, but the two things they don't provide are individualized absolute phase response and distortion figures, which isn't surprising given those are the two hardest things to actually measure.
Old 13th October 2010, 06:42 PM   #27
percy is offline percy  United States
just bumping this up to see if anyone has any new information to add.
Old 13th October 2010, 07:29 PM   #28
Pano's Avatar
Yes, what ever happened? Any news?
Old 19th October 2010, 07:24 PM   #29
Heh. I was actually thinking about this the other night - I just haven't had the time to pursue it. It's still on the list, I just don't know when I can get to it.
Old 19th October 2010, 07:45 PM   #30
Ron E is offline Ron E  United States
Ron E's Avatar
Idea for estimating THD at spot frequencies:
Measure a woofer at a specific SPL with a mic distance of 1 meter
keep halving the mic distance and record the spectrum. Eventually the spectrum will change and it won't be due to the speaker since it is playing at the same SPL. This should work OK at low frequencies, anyway...
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley
ECM8000 - THD and IMD performanceHide this!Advertise here!
How to do IMD simulation in LTspice!!! nicholas1113 Solid State 40 23rd February 2017 04:51 PM
OT: how can I measure THD of my amplifier if my sound card is 0,02% THD ? ygg-it Solid State 1 13th June 2010 07:54 AM
Imd hemgjord Tubes / Valves 7 28th July 2009 10:51 PM
Near ZERO IMD buffer amp wenye Solid State 37 20th April 2009 07:50 AM
What causes IMD? gmikol Chip Amps 4 4th January 2006 07:45 PM
