Old 21st July 2010, 10:50 PM   #1
Mayuri is offline Mayuri  Finland
Mayuri's Avatar
Default Vifa TC18WG69 enclosure help
Hello everyone!
I am completely stuck with designing enclosures for this driver. I've tried to consult WinISD, but I only get either a HUGE enclosure (83 litres tuned at 30 Hz), or a nice sized enclosure with a huge spike around 100 Hz and an organ pipe for the reflex channel.
Here's the driver specs: Riviera Acoustics - TC18WG69-08 Midwoofer
I was hoping to build a nice bookself speaker with these drivers since I got them real cheap second-hand, but the project isn't going anywhere now. I know the enclosure shouldn't be larger than the Vas of the element, so the 83 litres seems ridiculous. Should I just sell the drivers, since they've been only collecting dust, or can I actually get something useful out of them?
Best regards,
Simo
Old 21st July 2010, 11:18 PM   #2
Inductor's Avatar
If you have the time I would consider/suggest using the simulator from Wayne Parham instead of WinISD at the PiSpeakers Website. Go to: Pialign Analysis Software to help you design your enclosures. This is the old DOS original from 1977.
Pi Speakers - unmatched quality and state-of-the-art performance
Old 21st July 2010, 11:36 PM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
Originally Posted by Mayuri View Post
I was hoping to build a nice bookself speaker with these drivers ... can I actually get something useful out of them?
I have mine TC18-49 - same driver specs, different frame, in a 24L sealed box, actually I wish I had gone a bit smaller. Probably not smaller than 12 liters. Not that critical...
anything with Qts>0.4 will require Vb>Vas in a vented box.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 22nd July 2010, 10:00 AM   #4
Mayuri's Avatar
I might check it out one day, but right now I don't have the time to learn to use a new simulating program
Didn't know that, thanks! WinISD gives me 37 litres for the sealed box with Qtc of 0,707, which is a tad bit large. If I reduce it down to 12, the Qtc is almost 1. But I guess we have to make compromises
Old 22nd July 2010, 10:59 PM   #5
Ron E's Avatar
There is nothing magic aboput a Qtc of 0.707 - 1 even sounds better on much material. My boxes sound too lean, honestly, and I like lean bass...
Old 23rd July 2010, 08:27 AM   #6
Mayuri's Avatar
Alright, I see it now. Thanks kindly for the help!
Old 26th July 2010, 08:03 AM   #7
Mayuri's Avatar
What Tangband/Monacor tweeter would you guys recommend to go with this driver?
I was thinking of this Tangband driver, would it work?
Old 26th July 2010, 11:32 PM   #8
Inductor's Avatar
The problem is not with the tweeter. That tweeter looks marvelous (on paper). The problem is with the xover frequency, and/if the midwoofer can resist at around 1K to be merged at xover band. (This is) If you 'r pointing for a textbook 2K5/3K xover and you can design the xover, look at frequency output at/around 1KHz. How are you about solving the peaks and dips?
Old 27th July 2010, 07:30 AM   #9
Mayuri's Avatar
I was actually going to do an active speaker with a Tripath Ta2020 or 2024 stereo amp. One channel would be feeding the tweeter, other the bass. So I could (and will) use a line-level Xover.
Old 25th September 2010, 05:28 PM   #10
Mayuri's Avatar
Hello again!
I've made no progress at all with these drivers, until my cousin informed me she needs a pair of speakers. I have 4 of these drivers, and intend to do a floorstanding pair with 2 of these in each. The speakers would have about 30l internal volume, sealed enclosure. They would be placed next to a concrete wall. I'm planning of doing the xover low, 6db/oct at 1kHz and maybe putting a full range or a tweeter that can go low on the upper end.
Would this work?
Enclosure for Vifa 4" midrange driver? eRiCdWoNg Car Audio 9 6th March 2007 12:56 AM
Enclosure size for Vifa woofer trunkmonkey Multi-Way 10 7th October 2006 08:13 PM
Enclosure volume for VIFA K10MD midrange murat Multi-Way 0 11th February 2005 09:27 PM
Vifa PW17J in a TL enclosure ashok Multi-Way 22 8th June 2004 10:51 PM
Vifa P13 enclosure Mos Fetish Multi-Way 9 26th July 2003 05:17 PM
Page generated in 0.10781 seconds (78.63% PHP - 21.37% MySQL) with 10 queries
