Old 18th July 2010, 08:08 PM   #1
Audist is offline Audist  United States
Default Woofer for 2.5 way or 3 way loudspeakers
Hi there.
I looking to design 2.5 way or 3 way loudspeakers.
I want to use with Morel SCM634 carbon midrange (this driver can down to 40Hz?).
For the Bass. I think to use with Morel CAW938 or UW1058 in closed box.
Somebody please tell the differences between them and the sound quality.
B.N: EgglestonWorks Nine use with Morel CAW938 woofer.
Old 18th July 2010, 10:48 PM   #2
Inductor's Avatar
Originally Posted by Audist View Post
Hi there.
1. Interesting.
2. Morel SCM634 Supreme 6" Midrange. This driver is 4 ohm. Fs on the 50's (is not a best choice for bass, regarding of giving a good midrange). Looks pretty good from specs. https://www.madisound.com/store/prod...oducts_id=8485
3. You can look at an MTM/3-Way I did some time ago for a forum member, and transform it to a MMT. (If you like the idea).
4. Morel CAW938 9" Woofer. Fs=31Hz 8 ohm. Looks good, as a bass. https://www.madisound.com/store/prod...oducts_id=8440
5. Morel UW1058 10" Ultimate Subwoofer. Fs=26Hz, 8 ohm. Looks very impressive. http://www.morelhifi.com/products/raw_subwoofers.html
6. The 6" Midrange connects well at 100/200/250/300Hz with the 9"/10".
Old 18th July 2010, 11:34 PM   #3
Inductor's Avatar
Your best bet should be a WWMT (with the 9"). Curious to see.
Old 18th July 2010, 11:39 PM   #4
Thanks Inductor,
I broke off a simulation of the units on WIN ISD. The Woofer SCW636 and SCM634.
I got a better result with SCM634 midrange over SCW636 woofer.
It seems also a good result even in 2 way system (Am I wrong?).
The 634 Midrange see 37Hz at -6dB (without room gain) vs 41 Hz at -6dB with the woofer 636 .
https://www.madisound.com/store/prod...oducts_id=8474
Thank you very much.
Old 18th July 2010, 11:43 PM   #5
Inductor's Avatar
Thanks Inductor,
It seems also a good result even in 2 way system (Am I wrong?)...
Sorry, I'm lost completely, maybe it's me. Can you, please rephrase. You are checking for the best midrange and... (that is)
(I will check with you tomorrow).
Old 19th July 2010, 01:13 AM   #6
Hi Inductor,
Sorry for my English.
I mean that Morel carbon midrange 634 produce better bass than the carbon woofer 636.
My dilemma is if to use with 2 x 6 inch in 2.5 way. Or 1 x 6" midrange + 9 or 10 inch woofer.
Thank you
Old 19th July 2010, 10:10 AM   #7
Inductor's Avatar
Hi Inductor,
Thank you
Imagine running your amp lower than 2 ohm. I didn't measure/simulate. Attention with 4 ohm drivers in parallel or xovers. The SCW 636 has Fs=40Hz more suitable for a 2.5. The Morel UW1058 is a specialty in it's own right.
Last edited by Inductor; 19th July 2010 at 10:11 AM. Reason: pic: www.lautsprechershop.de
Loudspeakers Gary Hubbard Multi-Way 4 19th July 2009 04:00 PM
loudspeakers deki Multi-Way 0 17th July 2005 12:11 AM
Loudspeakers Tiberius Parts 1 9th September 2004 03:02 AM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
Loudspeakers Vivek Everything Else 7 27th March 2001 04:14 PM
Page generated in 0.12238 seconds (73.38% PHP - 26.62% MySQL) with 11 queries
