Wiring a subwoofer and split for one channel
Old 16th July 2010, 03:59 PM   #1
waksie is offline waksie
Default Wiring a subwoofer and split for one channel
Hi All,
This is my first post , so forgive me for my rookie question . Im planning on building a stereo floor standing speaker setup. I have a 80 rms(4 ohm) dls split system with passive crossover and a 10 inch 250 rms woofer(4 ohm) for each box. Im planning on wiring it in series with a 2 ohm stable amp. My question is , running both speakers(1 sub and 1 mid + tweeter) per channel , on a 350 rms amp, will the power be split (175 rms each) between the two speakers in the box resulting in me burning my spit system ?
Old 16th July 2010, 10:04 PM   #2
roger_lew is offline roger_lew  United States
roger_lew's Avatar
Hi and welcome.
The RMS ratings for the speakers specify how much power they can handle before they fail not how much power they draw from the amplifier. How the power is split between the speakers is dependent on the impedance curves of the speakers and the crossovers/wiring. The amount of power that is delivered to the speakers is dependent on the volume knob.
Roger
Old 19th July 2010, 08:40 AM   #3
thanx Roger !
Wiring a subwoofer and split for one channelHide this!Advertise here!
Help wiring power to 3 channel amp with one plug chevy2410 Chip Amps 57 30th May 2007 06:28 PM
Subwoofer Wiring audiobahnkid592 Car Audio 4 18th March 2007 05:48 PM
Subwoofer Wiring Diagram boris333 Subwoofers 10 4th October 2005 11:16 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
MTM center channel wiring with 2 way active crossover mik Multi-Way 0 2nd April 2004 11:39 AM
Copyright ©1999-2017 diyAudio
