Old 16th July 2010, 02:50 PM   #1
Bill F. is offline Bill F.  United States
Bill F.'s Avatar
Default Thermistor L-Pad to correct dynamic compression
Woke up this morning with this odd idea on my mind :
How about making an L-pad using NTC and PTC thermistors tuned to the thermal properties of the loudspeaker's VC/motor system to compensate for loudspeaker voice-coil heating?
As VC temperature fluctuations cause a loudspeaker's Re to wander, dynamics are impacted by varying degrees of power compression, and the tuning of passive crossover networks becomes compromised. Perhaps this could fix both problems.
If you wanted to get a little crazy, you could even tune the thermistors to supply a touch of artificial dynamic expansion.
The obvious penalty, of course, would be the loss of sensitivity that comes with use of any L-pad, but if your application needs an L-pad anyway, this added functionality might make sense.
Anyone ever heard of this being done? A cursory search revealed nothing.
Bill
Old 16th July 2010, 02:55 PM   #2
Bill F.'s Avatar
Default Pic
Here's a diagram.
Old 16th July 2010, 03:18 PM   #3
So how are you going to find components with dynamic properties, time constants and stuff to match the voice coil heating process? I think in analog this will prove extremely difficult.
O.t.o.h, using current measurements on the speaker and some proper DSP, it should be possible to determine the change in impedance due to the temperature rise and compensate for it. I think the difficult part of it would be mapping the change in impedance to some kind of 'dynamic eq' or multiband compressor to get the proper power-compression-to-frequency curve.
Old 16th July 2010, 03:38 PM   #4
That may adjust for crossover values but the voice coil resistance will still fluctuate. How about a water cooled magnet structrue?
Don't use any passive crossovers and use all fully variable active crossovers and muliple amp channels.
Old 16th July 2010, 05:13 PM   #5
Bill F.'s Avatar
Yeah, that probably wouldn't be trivial.
However, IIRC, some other threads here seemed to indicate that instantaneous heating effects were less important than longer-term temperatures. Maybe you could sink the thermistors to the motor structure.
Old 16th July 2010, 05:14 PM   #6
Bill F.'s Avatar
And the thermistors compensate for that by raising the voltage on the voice coil as temps rise.
Old 16th July 2010, 05:31 PM   #7
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
An effective and quite practical solution
Old 16th July 2010, 05:42 PM   #8
Bill F.'s Avatar
Off topic, but you're preaching to the converted. I have a Rane RPM88 and an 8-channel amp.
Old 16th July 2010, 05:50 PM   #9
Originally Posted by Bill F. View Post
Off topic,
Ahhhh, but it is a viable solution.
Old 16th July 2010, 06:08 PM   #10
jcx is offline jcx  United States
the BeoLab 5 active loudspeaker has voice coil heating nonllinear compensation internally in dsp
good thermal modeling may be a little complicated:
http://www.klippel.de/pubs/Klippel%2...ransfer_03.pdf
Vinyl Record Cutting Dynamic Range Compression oldheathkitphil Analogue Source 25 1st May 2008 06:52 AM
intentional dynamic compression for MP3's squib Digital Source 11 14th April 2008 05:16 AM
Recording Dynamic compression Reality fab Everything Else 13 28th May 2006 10:46 PM
Dynamic range compression & FPGA marco72 Digital Source 2 24th March 2006 10:55 AM
Page generated in 0.09199 seconds (86.88% PHP - 13.12% MySQL) with 11 queries
