Old 15th July 2010, 09:46 PM   #1
Default misused subwoofer for 2-way
Probably not worth a large thread but today i accidentally
used this one up to 2Khz....
http://www.tb-speaker.com/detail/1208_03/w69-1042j.htm
This is a rather cheap "no frills" subwoofer and already known
in the forum.
May need a little EQ due to enclosure used but:
There are smaller and specialized bass-midrange units
that perform worse in the midrange ...
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 15th July 2010, 09:56 PM   #2
Ignoring TB's response curves which tend to be far too smooth the
impedance kink at 1KHz indicates some sort of problem the response
curve ii not showing, but if the impedance kinks you can be sure
something is there. edit : just noticed the minor kink at 300Hz.
The famous Kef B139 "racetrack" had a major problem at ~ 700Hz.
/Sreten.
Old 16th July 2010, 07:48 AM   #3
Attached some quick and dirty measurements.
The suckout below 1Khz is also partly due to
measurement conditions.
1st pic smoothing is 1/6 octave.
2nd pic smoothing is 1/50 octave
Concerning the IR have seen worse ones
from fullrangers.
This is in a BR cabinet.
www.dipol-audio.de
Old 16th July 2010, 09:48 AM   #4
I am crossing it at 2.3 Khz with "OK" result.
I guess 800 Hz can be made rather well, when
finding a sufficiently widerange driver for the highs.
www.dipol-audio.de
Old 16th July 2010, 03:26 PM   #5
Resulted in a nice party box, but good at strings and voices nevertheless ...
Widerange unit used as tweeter:
Monacor "SPX-20TB N" built into a stuffed tube.
e.g.
SPX-20TB Miniatur-HiFi-Breitbandlautsprecher, 30WMAX, 8Ohm MONACOR / IMG Stage Line günstig online bestellen
Sounds rather relaxed, even at higher levels.
The tweeter is driven fairly below its mechanical limits.
Blue:Woofer with XO
Red:Tweeter with XO
Green: Whole Speaker, Tweeter padded down a bit compared to "Red"
File Type: jpg WithXO_Woofer_Tweeter_WholeSpeaker.jpg (243.2 KB, 55 views)
www.dipol-audio.de
Old 16th July 2010, 05:17 PM   #6
Crossover wiring, RL parts are resembling the drivers (roughly).
Tweeter tube should be closed at the rear with dense foam plug e.g.
Tweeter tube arranged ontop of enclosure freely "B&W Nautilus style" .
When integrated into baffle, tweeters crossover will have to be changed.
Top: Tweeter
Bottom: Bass
You can cut the "Analysers" and their
wires away, to get the crossover wiring.
The simuation results at the right are not
reality, but close enough for a start.
Disclaimer:
"The crossover has been fine tuned by listening,
and may represent (strong) influence of the authors
listening room and listening habits."
Feel free to modify, according to your needs.
www.dipol-audio.de
Old 16th July 2010, 05:53 PM   #7
Need more thrust ?
Transpose crossover for 2 woofers in parallel ...
I mean, 1 Woofer is 50 Euros ...
www.dipol-audio.de
Overview about words largest Subwoofer Drivers/Transducers (SUBWOOFER BEAST) tiefbassuebertr Subwoofers 26 3rd March 2012 01:37 PM
Compact Subwoofer (I use subwoofer lightly) jjohnston Subwoofers 5 18th November 2009 06:55 PM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
I need help with subwoofer deisign: HUGE inexpensive subwoofer hottyson Subwoofers 16 4th May 2004 03:51 AM
Page generated in 0.09913 seconds (76.30% PHP - 23.70% MySQL) with 11 queries
