Hi Guys,
I am not a electrics guy so that is why I am coming to you guys. I bought these DIY speakers w/crossovers, I don't know how to interpret the xovers plans to you all. but the speakers themself are dymauido 8" 24w100 d-54af and ow-1 the cabs are 43" high 16" deep and 11.5" wide, the front & back baffle 1.5 thick and the sides I think are 1" thick. there are are a few flaw in the wood work so I would like to build new cabs so I would like some help in the right design. I live in Marysville Wa. thanks for any help you guys can give Robw102 |
#2 |
Custom Title
There's not a lot of information to go on there. I'd try restoring the cabinets as-is first, assuming they sound good and are well-designed.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#3 |
The drivers are well known and high quality. The cabinets sound about right for a vented low Fs 8" driver. Restoration is far easier than a total rebuild. The crossover has to be right for such drivers, do you know if its from a published design, from a vendor or knocked up by the original builder ? is it hardwired or on a board with some identifications ? http://www.gattiweb.com/images/dynaudio/24w100_data.pdf http://www.gattiweb.com/images/dynaudio/d54af_data.pdf Hiquphon OWI (OW1) dome tweeter features /Sreten. Last edited by sreten; 15th July 2010 at 10:23 PM. |
| what sounds best . . . Low Qts in small cab or higher Qts in bigger cab | mikelm | Subwoofers | 18 | 15th July 2009 10:46 AM |
| cheap 6" or 8" woofer to make great bass for a standard cab pick up | zuki | Subwoofers | 12 | 15th February 2005 07:54 AM |
| Which Sub for my cab? | usa_satriani | Subwoofers | 1 | 25th June 2004 08:39 PM |
| How make make a microchip, from a program? | multiplexor | Everything Else | 1 | 20th February 2004 01:24 PM |
| Page generated in 0.08237 seconds (72.48% PHP - 27.52% MySQL) with 10 queries |
