Posted this in exotics also, but was suggested to put it here too.
These are the two configurations I have come up with so far to keep height down a bit. Of the two, is one much better than the other? I would assume the W shaped baffle will make a more even front and rear wave since the drivers are equal and opposite in direction. I do have some conserns using angles smaller than 45 degrees, but it is imperative to keep the height down a bit. P.S. ignore the tweeters. I'm still playing with the top baffle configuration. Ideas/thoughts? Thanks, Blair |
#2 |
http://gainphile.blogspot.com |
#3 |
Both design from Blair and gainphile looks doable. I also try to squeeze 4 12" dipole woofers into narrow foot print. Any idea how 4 woofers configured in AudioArtistry Beethoven speaker system? The woofer box is 29"H x 14.75"W x 21.5"D. I believe it is designed by Linkwitz.
Welcome to Audio Artistry |
| H frame vs W frame dipole woofers | rick57 | Multi-Way | 18 | 8th October 2011 04:58 PM |
| Dipole frame options? | deicide67 | Planars & Exotics | 13 | 20th July 2010 02:15 PM |
| W-frame Dipole Construction Q | weinstro | Multi-Way | 9 | 20th August 2007 03:31 PM |
| any compromises in using Linkwitz W-frame dipole? | taloyd | Subwoofers | 9 | 6th July 2006 09:57 PM |
| H frame/ Dipole/U frame ???????? | j.burtt | Multi-Way | 24 | 1st May 2006 03:50 AM |
| Page generated in 0.06649 seconds (71.42% PHP - 28.58% MySQL) with 11 queries |
