With two cone drivers in the same cab, the total wattage of the cab is the sum of the wattage of the two. With a cone driver, a compression driver, and a crossover is the total wattage still the sum of the two?
#2 |
No, it's the lower of the 2. (in basic terms)
However, the compression driver is going to be attenuated to match the woofer/mid. So not all the power is reaching it. Plus,of course, the crossover divides the total power out among the drivers - however many you might have. 2,3,4 Simple answer: Usually with a cone and a horn in a 2 way, you are safe going by the wattage rating of the woofer.
Take the Speaker Voltage Test! |
#3 |
Thanks so much for your help!!
#4 |
Speakerholic
Only if they are the same driver. Otherwise as Pano says it basically 2X the lower powered unit no matter what the drivers.
#5 |
Its not that simple when the bandwidth of the two drivers is not the same. The wattage as defined for the compression driver is always band limited while that for the woofer is usually not. How the power is split between the two is also a factor. What Pano said is the simplest answer but not always accurate.
#6 |
True, if you don't know how much the compression driver has been attenuated or what the crossover slopes and points are. That determines how much power gets to the CD.
So you still might want to be careful. =) |
#7 |
#8 |
In theory...with power compression in reality, doesn't always work out that way
Jim J. |
| Compression driver protectioon? | jayam000 | Multi-Way | 10 | 6th April 2010 05:58 PM |
| Compression driver watts? | mhtplsh | Multi-Way | 9 | 11th September 2009 06:19 PM |
| Does preamp wattage effect power amps wattage? | JonnySwitchblade | Solid State | 7 | 4th July 2007 03:18 AM |
| FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) | theAnonymous1 | Swap Meet | 0 | 24th April 2007 12:09 AM |
| Page generated in 0.08873 seconds (73.06% PHP - 26.94% MySQL) with 10 queries |
