Looking for a little advice. I am building a BIB style speaker with the Fostex 208EZ (yes big....) and using fountek neoCD 2.0 as an adjunct tweeter to fill out the top end.
I am planning a higher cross over, 8000hz or so, to utilize the 208ez a bit more (they do have phase plugs) and use the fountek's lower end a little less. 1st order, simple plan. The question is that the fountek is 95db 1W/1m, 7ohm with a built in zobel the fostex is 97db 1W/1m 8ohm with my added zobel. Is this small sensitivity mismatch important, or will the small impedance difference make up for it? I will be using some digital room correction/equalization, so I figure that could make up for small issues better than trying to attenuate the woofer, but would like to hear some knowledge. I was not planning any BSC as I am a little worried I will have too much bass in this system anyway due to my room configuration and the super-size BIB. I would think BSC would only make the driver mismatch worse, but correct me if I am wrong. I have not really figured out, or done sufficient research to determine how the box will affect speaker sensitivity, so input (or pointing to learning sources) will be educational. I am not willing to use active cross overs, so no suggestions along this line. Thanks in advance!! |
#2 |
Ok, now I have seen several listed sensitivities of the neoCD 2.0 showing 95db 1W/1m, 97db and 98db. Anyone have a sense what it really is? Or should I just not worry about it....
| fostex 208ez and fostex ft17 h good kombo? | almightybozo | Full Range | 1 | 24th September 2010 06:00 PM |
| FS (3) Fountek NeoCd 2.0 tweeters | Guiness | Swap Meet | 1 | 24th January 2008 10:36 PM |
| UK) For sale: Fountek NeoCD 3.0 ribbon tweets, or Wanted pair of Jordan JX92s | Puggie | Swap Meet | 4 | 27th January 2007 03:06 PM |
| active 2 ways with SPH-165KEP and Fountek neocd 3.0 | Nemophyle | Multi-Way | 4 | 26th July 2005 09:29 AM |
| Founteks new NeoCD ribbons | dkxdn | Planars & Exotics | 4 | 22nd April 2005 10:16 AM |
| Page generated in 0.07785 seconds (73.50% PHP - 26.50% MySQL) with 10 queries |
