Old 7th July 2010, 10:16 AM   #1
Default Vifa M11MG-09-04 possible repair or what replacement
Hi
I got Infinity Kappa 90 loudspeaker system bought In 90s
I noticed that I have weird distortion on quite passages of music (at the beginning or end of track)
distortion Is on midfoofer which Is Vifa M11MG-09-04
could this midfoofer be repaired or what Is best replacement
cheers
Old 7th July 2010, 05:43 PM   #2
Inductor's Avatar
First check if you can repair the driver (or the xover). Find where the fault is. Some places (or countries) you can find repair shops. Next, if you want check for a substitute go look for the same or investigate a similar driver for the same parameters. (The 4 Ohm is quite different from the 8 Ohm, in frequency output, in this case). If you substitute (test), substitute the pair for a good stereo-phonics.
PL11WG09-04
Old 10th July 2010, 08:22 AM   #3
thx for your reply
when I turn volume high to very high I don't have that Issue - any thoughts ?
also I have found another Vifa midwoofer but 8 Ohm and when I placed - It Is OK - so I think xover Is OK
PL11WG09-04 Is discountinued
Replacement Vifa C17WH-09 08 helios999 Multi-Way 8 4th September 2010 10:39 AM
Vifa M22WR-09 08 lust4sound Swap Meet 0 18th March 2009 03:52 AM
XO for Vifa PL18WO-08-09 and Vifa XT25TG30-04 MTM knightat83 Multi-Way 6 24th January 2009 08:51 AM
Vifa M17WG-09-08 still available? macaque Multi-Way 0 27th May 2005 01:29 PM
2x Vifa M17SG-09-08 + ??? MiG Multi-Way 3 10th March 2005 02:43 AM
Page generated in 0.07194 seconds (67.92% PHP - 32.08% MySQL) with 10 queries
