i'm being told different things- a bypass cap in the woofer circuit doesn't make a difference. only enough so that it still doesn't justifies the price, yes it does, go for it. please help me decide. the design in question is Jim Holtz's Statement monitors. sorry for the lack of description but as you might realize im a complete noob at crossovers. http://www.speakerdesignworks.com/St...allBOM2010.pdf
#2 |
In the schematic I found by googling, http://www.geocities.com/cc00541/Sta...Monitor_2.html
the cap in the woofer circuit makes the xover 2nd order; it will make a difference. For a noob, don't deviate from the original design unless the designer gives you a reason to - ask him?
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky Last edited by PeteMcK; 7th July 2010 at 04:42 AM. |
#3 |
not deviating at all. the woofer cap is 70uf. i have it paralleled with 30uf and 40uf metal caps in my crossover. just wanting to replace the 30uf cap with three 10uf foil caps
#4 |
The generally accepted "tuning" wisdom is that the quality of series capacitors affect the sound more than parallel ones, this for most time must be true. In your case "upgrading" what are essentially roll-off capacitors for a bass unit I'd regard as as waste of time if you already have decent capacitors. /Sreten. |
#5 |
I would consider testing and improving in a 2-way (typical 2K5). In here, not the case, a 3-way, the curve of the woofer on the lower frequency side, is going to be more difficult for you, to find any differences between the caps.
| Header bypass Cap? | toufu | Tubes / Valves | 2 | 23rd June 2010 05:33 PM |
| Replace Bypass Cap? | Monjul | Tubes / Valves | 42 | 9th April 2010 10:19 AM |
| Polar electro with bypass cap to replace nonpolar as coupling cap? | at77 | Parts | 0 | 12th January 2010 02:05 AM |
| suitable bypass cap | Stefanoo | Solid State | 0 | 26th May 2009 10:50 AM |
| Cathode bypass cap ? | woody | Tubes / Valves | 2 | 19th May 2002 05:53 AM |
| Page generated in 0.08592 seconds (73.87% PHP - 26.13% MySQL) with 10 queries |
