I am looking around for a good 2-way design that would give me a little more extension and output in the lower end of the spectrum than a typical bookshelf or MTM (hence the mention of floorstanding). That does not mean I am completely ruling out large bookshelf or mtm. If there is a design that you know of please do suggest. I'd like to cap the budget ~USD600 completed with parts and cabinet.
Thanks! |
#2 |
SEAS CNOcost no object
but if want want solid bass, 2.5 way would be better CNO 2. http://www.zaphaudio.com/Waveguidetmm.html might be abit more affordable
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky Last edited by PeteMcK; 7th July 2010 at 02:14 AM. |
#3 |
I've checked on the links and it is good only for 6.5 inches driver.How about a 2 way enclosure design for 12 inches woofer? anybody please....
#4 | |
You need to first say what frequency response and sensitively you want. This would be determined by the size and kind of amp you have and the size of the room and how loud you want the sound to be. Next you might constrain any solution by placing a limit on the cabinet size and making a budget. Next you look at possable designs and may find you can't have all of the above to you relax some requirements or contraints. It may turn out the best design uses a 12" woofer and is a two way system or not no one here would know because we don't know your goals. No need to think about the nuber and size of drivers until you are clear on how and where the speaker will be used |
#5 |
#6 |
to expand on what ChrisA mentioned above, it's always fun to offer helpful advice, but without understanding your needs/ specific application constraints, a lot of time could be wasted "solving" problems that may not exist
start with : room size/ listening position(s) type of listening ( program materials/ desired SPL levels, casual background /home theatre etc) available or anticipated amplifier power "domestic acceptance factor" - don't restrict yourself solely to concept of large bass driver/2 or more way systems - some excellent performance is available in compact footprint but possibly taller floorstanding enclosures using multiples of smaller or even full-range drivers (but not quite qualifying as true line arrays)
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#7 | |
let read Zilch's posts
flesh flash flush |
#8 |
R.I.P.
There's eight of them in this thread thus far:
Flex Your PCD Mettle: - Techtalk at Parts-Express.com And two more in the works. [Project summary links in the first post.... ]
#9 |
(on techtalk@partsexpress)for some unexpected reason
"The administrator has banned your <my >IP address. To contact the administrator click here"and when I click there, I see "The administrator has banned your IP address. To contact the administrator click here" etc.
flesh flash flush |
#10 |
| Floorstanding woofer advise? | Lewis Moon | Multi-Way | 7 | 11th February 2009 05:40 PM |
| Recommend a floorstanding 2-way to build? | happyb | Multi-Way | 6 | 12th March 2006 03:39 PM |
| help on building floorstanding speakers | sr2002 | Multi-Way | 5 | 25th August 2005 07:18 AM |
| Vifa Floorstanding Speakers | Big Kev ! | Multi-Way | 18 | 28th May 2005 02:33 AM |
| floorstanding speakers tweaking | manuel_8904 | Multi-Way | 4 | 3rd June 2004 10:24 PM |
| Page generated in 0.11393 seconds (79.87% PHP - 20.13% MySQL) with 10 queries |
