Old 5th July 2010, 07:44 PM   #1
Defo is offline Defo  Norway
Default Have anyone tried this? A floor - sidewall "horn" sub
Have anyone tried to "horn" load a sub as illustrated below, using the floor and wall? Not as a normal corner horn, but only the floor and sidewall as implemented below. Just an idea
Old 5th July 2010, 08:18 PM   #2
Assuming free space (ski lift conditions) adding the
first wall behind the speaker will give you 6db gain
in sound pressure.
The next wall making up a 90 degree edge will give
you another 6db ...
Positioning in an edge - but not in corners - with
radiation axis parallel to the edge is a nice thing
to improve sound pressure from a dipole subwoofer.
A monopole can even be placed in a corner.
But in a real room things look different due to
excitation of room modes.
Nevertheless, there is nothing wrong with the
idea and a position in an edge of the room
can be tried for a subwoofer.
Kind Regards
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 5th July 2010, 08:36 PM   #3
jeno is offline jeno  Norway
Martion does this with the bass section of his Orgon horn system when he has no corner available.
MARTION AUDIOSYSTEMS >> Gallery ORGON
Old 5th July 2010, 10:39 PM   #4
Cool, thanks Looks like this will be my next bass solution!
Old 6th July 2010, 11:53 AM   #5
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Originally Posted by Defo View Post
..the floor and wall?..
or the ceiling and wall?..
flesh flash flush
Old 6th July 2010, 12:20 PM   #6
Should in many cases be no difference in case of
a subwoofer, if you find a good place in a bottom
edge you may find one under a ceiling edge as well.
And the sub gets "out of your feet" and saves place.
In fact you may have often more space for variation
of the position under the ceiling.
Kind Regards
www.dipol-audio.de
Old 6th July 2010, 12:28 PM   #7
Whatever floats your boat
Old 6th July 2010, 12:35 PM   #8
Is that a norwegian idiom or english ?
Sounds good.
www.dipol-audio.de
Old 6th July 2010, 01:37 PM   #9
Flaesh's Avatar
my boat isn't box))
flesh flash flush
Old 6th July 2010, 01:48 PM   #10
bear's Avatar
It's basically called a Klipsch Corner Horn...
The problem, if there is going to be one is that it is very very very room dependent. In some rooms the Klipsch sounds wonderful, in others, no bass at all.
Ymmv.
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Horn-loading the "new breed" of pro sound 6.5-8'' drivers Swedish Chef Multi-Way 61 28th April 2006 01:01 AM
Can I multiply an 18" folded horn cab by 0.8 for a 15"? Optical Subwoofers 7 31st October 2004 04:37 AM
Data of Isophon DKT11 "Exponential-Hochtonstraler", treble horn peranders Multi-Way 3 10th December 2002 08:13 AM
Page generated in 0.10413 seconds (80.10% PHP - 19.90% MySQL) with 11 queries
