Old 5th July 2010, 11:16 AM   #1
Default within passband phase inversion
Ran some HolmImpulse tests on a 2-way system I'm developing. The resp/phase results showed 2 phase inversions. One at the crossover point of 2500 hz (expected) and another within the woofers pass band, around 400 hz.
I don't understand the latter. Room mode effect perhaps? I'm testing the speaker in a 13 ft sq room with the speaker pointed on a corner to corner direction to minimize reflections/mode effects.
Any help would be appreciated.
xover is 2 order LP and 3rd hp.
Old 5th July 2010, 03:27 PM   #2
Pano is offline Pano  United States
Pano's Avatar
How far away is the measurement mic? Meaning - how much room tone are you getting?
Take the Speaker Voltage Test!
Old 5th July 2010, 03:29 PM   #3
one meter. speaker is well off the floor sitting atop another speaker.
I"m the same poster as at the HI in practice thread.
Old 5th July 2010, 03:35 PM   #4
Pano's Avatar
Yes, I saw you over there.
Well at 1M and up off the floor, it may not be room. I see some odd phase kinks in my woofers, too. Not sure what causes them. Maybe cabinet resonances? Baffle kinks?
Here's a thought. How does it measure out of the cabinet, just naked? Or on a simple baffle board? Or with no crossover in place?
Old 5th July 2010, 03:57 PM   #5
Haven't done any BB measurements with HI. I used ATB PC Pro during my BB dev. phase and just did WT impedance T/S stuff on the bare woofer.
When I transfer the HI file over to my desktop I'll post a pic of the speaker resp/phase I'm asking about. Maybe that wll help.
I checked cabinet resonances this morning and they are minimal.
Passive phase inversion? TequilaKez Parts 4 6th October 2008 01:38 AM
Op-amp for signal inversion. K-amps Solid State 10 24th November 2006 03:36 PM
Avoid polarity inversion MaXiZ Everything Else 7 3rd March 2004 05:55 AM
Polarity Inversion circuit ashok Everything Else 17 5th April 2003 11:32 AM
Page generated in 0.10214 seconds (69.41% PHP - 30.59% MySQL) with 10 queries
