I have recently become interested in the Audax HM100CO as a bass/midwoofer driver for a mini monitor, to be paired with one of the Vifa 1 In. ring radiators. The Audax has a Qtc of .21. A crossover freq. of around 2500 Hz has been suggested, with a 6dB crossover on the woofer and a 12 dB crossover on the tweeter. I might also use the LEAP service available through Madisound.
Audax's own spec sheet recommends a vented enclosure of 10 L. In order to compensate for the volume taken up by the drivers, vent, and crossover (although these may be mounted outside of the box), I am thinking that a gross volume of 12 L should work. This is my first vented two-way. I have built a full-range and two two-way sealed speakers. Given my preferences and experience with sealed speakers, I prefer the best transient respone over bass response. I would use a Paradigm PDR8 sub to bring up the bottom end. I am asking for advice from anyone who has worked with this driver in a similar fashion. What has worked for you? BTW, are there any calculators for determining interior box dimensions, (not volume)? Regards, Karl |
#2 | ||
I wouldn't use this driver in a net. 12L ported box but in a TQWT = offset TL instead in order to avoid a sagged FR. In case a ported box is the absolute preference, I would use a volume of no more than 2 L and pass over to an overlapping sub at about 80-120 Hz to achieve a full grown sound stage. Quote:
and build a 34 L (~1.2 cu. ft.) BW-max= ~34-120Hz T-TQWT (Tapped Tapered Quarter Wave Tube) folded on or two times for maximum compactness?b
#3 |
bjorno -
Sorry for the long dalay in replying. I've been very busy lately. I do appreciate your response to my query and the work you did in simulating a TL. Unfortunately, I cannot read the screen image of the simulation; it comes up 'too small." Would you be able to enlarge it and then resend it as an attachment as you did before? You also suggested a 2L sealed enclosure. Would that work well given that the driver has a Qts of .21? I prefer sealed enclosures due to their transient response. My Paradigm sub has a variable crossover range, I believe, of between 50 and 150Hz. Thanks for your help. Karl |
#4 |
bjorno -
I just noticed my mistake regarding the last post. I was mistaken regarding the 2L enclosure. I should have realized that it could not be sealed. BTW, how would the transient response of a TL compare to that of a sealed or vented enclosure for this driver? Regards, Karl |
#5 | |
The simulated impulse responses looks IMO good for both the TL and the Ported Aperiodic Box. See the pictures: b |
#6 |
bjorno -
I was able to enlarge the first thumbnail and take a look at the information. Again, thanks. That's going to make a pretty small cabinet. I assume that this is for a mass-loaded TL. Should I allow extra volume for the Audax and a tweeter? If so, how much? I would mount the crossover externally. Regards, Karl |
#7 |
bjorno -
Which enclosure would you recommend? The height and size of the TL would be no problem. Are there any sonic advantages of one over the other? Regarding the TL, I believe Sd is the diameter of the driver. Is this correct? If so, how critical is the measurement of the cone? Some manufactures do not accurately measure a driver's diameter (there are some "8 Inch" drivers that are much closer to six or seven inches). In other words, should I measure out to the flange, to the surround, or just the cone itself? I am going to check out Martin King's papers again (it's been a long time) to learn the terminology and his derivations. Regards, Karl |
#8 |
bump - looking 2 build a 2 way with this mid range unit...
| when designing a 2 woofer enclosure... | slicemaster101 | Multi-Way | 33 | 5th April 2012 05:55 AM |
| Designing enclosure volumes | Syncroniq | Multi-Way | 4 | 6th June 2008 11:09 AM |
| Help designing enclosure ATC sb75-375sc | tf1216 | Subwoofers | 1 | 8th July 2006 01:25 PM |
| help designing an enclosure | felzi | Subwoofers | 7 | 5th July 2005 05:20 AM |
| AUDAX PR240MO or PR300MO BEST ENCLOSURE | PTSOUNDLAB | Multi-Way | 23 | 10th June 2002 11:48 AM |
| Page generated in 0.10814 seconds (74.26% PHP - 25.74% MySQL) with 11 queries |
