Much has been said about the GW-1858 as good OB woofers , but what about the GW-215/4 , they look pretty interesting and seem to have good specs for an H-frame OB matched to a 3" or 4" Full range
Anyone have experience with them? Please can someone suggest an H-Frame for it? Thank you |
#2 |
Hi tonytex,
I have not used this speaker but have listened to Carver dipoles with a similar high Qts ~ 2 and thought that the bass was sloppy and undetailed. For an H-baffle I favor a Qts between 0.7 and 0.8, since the motor still is strong enough to have good control of the cone motion. The air mass loading of the H-frame will slightly increase Qt. I think you would get noticably better bass from the GW-1858. It would be safest to copy one of GM's documented and reviewed designs from quaterwave.com. Just accept the larger H-baffle. In the USA, the Acoustic Elegance IB15 speaker looks like a very good dipole choice for $125-$150. The efficiency is low at 87 db, and two IB15s are often wired in parallel and run from a plate amp. FROM PARTS EXPRESS GW 215: These low frequency OEM drivers are ideal for the customer who is looking for inexpensive replacement woofers. Each woofer features a treated paper ribbed cone, vented pole piece, moisture resistant poly foam surround, and stamped steel frame. Specifications:*Power handling: 135 watts RMS/250 watts max *Voice coil diameter: 1-1/2" *Le: .9 mH *Re: 7.1 ohms *Frequency response: 27-1,200 Hz *Magnet weight: 20 oz. *Fs: 29 Hz *SPL: 87.8 dB 1W/1m *Vas: 12.95 cu. ft. *Qms: 7.08 *Qes: 2.69 *Qts: 1.95 *Xmax: 3.5mm *Dimensions: A: 15" B: 13-3/4" C: 5-3/16" *Net weight: 5 lbs. Acoustic Elegance IB15 Fs: 16Hz Qms: 6.8 Vas: 439L Cms: .45mm/N Mms: 220g Rms: 3.239 Xmax: 18.5mm Xmech: 25mm Sd: 830sqcm Vd: 3.07L (p-p) Qes: .78 Re: 5.5ohm Le: .33mH Bl:12.49 Pe: 500W Qts: .7 1WSPL: 86dB 2.83V: 87.3dB Physical dimensions: Cutout hole: 14" Outer diameter: 15.5" Mounting Depth: 7.5" Overall Depth: 8" Weight: 19lbs |
| MJK’s Jordan JX92S OB with a Goldwood GW-1858 Woofer in an H Frame | Jim Shearer | Full Range | 606 | 25th April 2012 11:11 PM |
| FS: Goldwood GW-1858 18" woofers - $110 | xecluded | Swap Meet | 6 | 28th May 2010 02:13 PM |
| Canadian GB for Goldwood GW-1858? | Aengus | Group Buys | 93 | 16th September 2009 03:11 PM |
| PIONEER B20FU20 or GOLDWOOD GW-8003/8 | sandman | Full Range | 13 | 18th November 2006 07:27 AM |
| Goldwood GW-1038 for Dipole?? | abpea | Subwoofers | 7 | 8th December 2004 02:53 AM |
| Page generated in 0.07594 seconds (70.45% PHP - 29.55% MySQL) with 10 queries |
