Old 2nd July 2010, 02:11 AM   #1
bcherry is offline bcherry  Hong Kong
bcherry's Avatar
Send a message via Yahoo to bcherry
Default LS35a Experts
I have a pair of Rogers 15ohm LS35a with haven't been played for many years. Yesterday I hooked them up in my home system and 1 voicecoil is rubbing. Turned them upside down and they were OK for a while then started rubbing again so the surrounds and spider have deteriorated. I also have in hand a pair of new original KEF110 drivers but I've been told they are not a drop in replacement as Rogers would dope the 110's to tune them for use in the LS35a.
Does anyone know if that is true? Has anyone everyone just replaced the original drivers with standard KEF110?
thanks
Brian
Disclaimer: I may or may not offer for sale items mentioned in this thread, and if I do, I may or may not make a profit.
Old 2nd July 2010, 03:14 AM   #2
Inductor's Avatar
The original KEF110 (reference?) should be a 15ohm for the LS35a you mention.
I'm not Kef/pro but look here for various models: museum worthy KEF speakers?
Old 2nd July 2010, 04:29 AM   #3
frugal-phile(tm)
planet10's Avatar
Nope. It was the standard 8 ohm B110 SP1003.
Part of the disrepency is that the 15 ohm LS3/5A isn't really 15 ohms, and the rest is the XO.
They ar ematched, but i've never seen extra doping on them.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd July 2010, 09:23 AM   #4
The LS3/5 was a BBC design.
To be allowed to use the LS3/5 designation none of the manufacturers (Rogers, Spendor,Harbeth et al) were allowed to deviate from the BBC spec at all.
Hence it would have been illegal for Rogers to use extra doping.
Old 2nd July 2010, 01:53 PM   #5
Inductor's Avatar
Originally Posted by bcherry View Post
I have a pair of Rogers 15ohm LS35a...
Brian, I must admit that, if your reference is incorrect, you might need a KEF type B110 unit (SP1003) with nominal impedance of 8 Ohms (Rdc=7,1 Ohm), Fs: 35Hz with limits being 33 and 40Hz. Your reference for this speaker, is then (should be), a nominal impedance value of (modulus) 12 ohms. (as in "The design of the miniature monitoring loudspeaker type LS3/5A", 1976).
Old 2nd July 2010, 02:31 PM   #6
bcherry's Avatar
Brian, I must admit that, if your reference is incorrect....
This is what I have. There is so much info on the LS35a, not always in agreement so finding it difficult to know what to do with these. Some say it is a common problem, caused by magnetic speaker stand, the amplifier mismatched etc. Thanks for the comments so far. I'll need to check if the B110 I have are the ones mentioned above.
Does the attached pic of the nameplate on the back help?
Old 2nd July 2010, 04:27 PM   #7
frugal-phile(tm)
planet10's Avatar
Brian,
Same label as on the pair i am restoring.
dave
Old 2nd July 2010, 07:10 PM   #8
dave and bcherry,
Any general comments on the sound of the LS35a version you have versus "modern" speakers, while they were working?
And dave, how does it compare to your single driver "onken" style FE127E speakers
I haven't heard a pair for many years, but the pair I heard sounded subdued and undynamic (dead). Probably, the components dried up, so I did not know what the attraction was all about.
Old 2nd July 2010, 10:52 PM   #9
bcherry's Avatar
Originally Posted by ultrakaz View Post
dave and bcherry,
Immediately reminds of the 'voice of the BBC' and 6 o'clock news sounds from when I was growing up on the BC coast. Sound is always pleasant and imaging is very good. For a small speaker it does a particularly good job of hiding the fact that there is no real bass.
It also has the attributes of a sealed box design -- meaty transient attack and smooth response.
However having been so long away to open baffles, compression horns and ribbons, and field coils etc, it does sound subdued. There is just too much missing for even a second system for me. My wife likes the LS35a but when I replaced them with a corian cabinet speaker of not much bigger size and with a ribbon tweeter, she went "wow," especially on some massed African vocals.
Brian
Old 2nd July 2010, 10:59 PM   #10
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
dave
and what an xo it is -
from here
Rogers Speakers - BBC LS5/9
advice from the experts notaclue Multi-Way 6 11th July 2006 10:24 PM
A Question To The Experts Here mastertech Solid State 16 6th March 2006 11:52 AM
Need help from the experts bateman Multi-Way 1 22nd June 2003 02:29 AM
Page generated in 0.11855 seconds (77.96% PHP - 22.04% MySQL) with 11 queries
