Sonus faber amati !! Diy
Old 25th July 2011, 01:46 PM   #31
johnbomb is offline johnbomb  United States
Originally Posted by juliovideo View Post
There are many techniques for bending wood or plywood,in my case I used plywood with termination oak, the plywood was immersed in water for 30 minutes and then forced into the structure made, depending on the environmental humidity takes between 2 to 3 days to dry........and then to glue.
I used two layers of plywood 1 / 4 inch, total thickness 1 / 2 inch per side,each speaker weighs about 120 pounds.
Example of some techniques......
Plywood Bending
‪plywood bending‬‏ - YouTube
Wood Bending
‪wood bending‬‏ - YouTube
Thanks!
Old 15th June 2013, 06:14 PM   #32
Dan998 is offline Dan998  United States
Check out these Sonus Faber Amati Homage Clones.
There at the bottom of the page and in white.
They look amazing.
http://www.htguide.com/forum/showthr...ub-Sonus-Faber
Old 15th June 2013, 10:39 PM   #33
Here's the right link to the Sonus Faber Amati Homage Clones. Its at the bottom of the page.
http://www.htguide.com/forum/showthr...us-Faber/page3
Old 15th June 2013, 11:06 PM   #34
lduarte1973 is offline lduarte1973  Portugal
Banned
Impressive work , one of the best ive ever seen
Old 15th June 2013, 11:10 PM   #35
It looks like the Amati Homage clones are using 2 Scanspeak 8 inch woofers, Skaaning midbase and Scanspeak Ring Radiator tweeter.
Old 15th June 2013, 11:11 PM   #36
I wonder who built that cabinet. That cabinet looks unreal.
Old 15th June 2013, 11:55 PM   #37
Silent Screamer is offline Silent Screamer  Australia
Disappointing... You put the time and effort into the cabinet only to let it down with the drivers. As an owner of a genuine pair of Cremonas I can tell you that your cabinet work and crossover is on par with the Cremonas, but below that of the Amati's. fantastic effort but please change the drivers to something more worthy.
Old 16th June 2013, 12:46 AM   #38
Doug Kim is offline Doug Kim  South Korea
Doug Kim's Avatar
The final lacquor finish should be improved a little bit, for the actual Sonus Faber like shiny finish. This is such a nice work. Just a bit of touch would make this perfect.
Thanks for sharing.
Doug
Old 16th June 2013, 01:02 AM   #39
Studio Au is offline Studio Au  United Kingdom
Can the drivers used by Sonus Faber be purchased off the shelf?
Old 16th June 2013, 01:54 AM   #40
Nearly... You can buy the same make and model but the SF drivers are mildly tweaked for SF.
Sonus faber amati !! DiyHide this!Advertise here!
Sonus Faber Electra Amator DIY? mot on/off Multi-Way 28 8th March 2014 09:20 PM
Sonus Faber stradivari B4 Multi-Way 6 2nd August 2008 02:31 PM
Help me with SONUS FABER AMATI clone skatavic Multi-Way 3 8th July 2008 02:57 PM
Which midrange used in Sonus Faber rinx Multi-Way 27 20th June 2008 10:59 PM
Sonus faber cremona jouch Multi-Way 10 22nd September 2006 06:57 AM
