flush\inwall\ib project. questions as they arise
Old 29th June 2010, 10:29 PM   #1
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Wink flush\inwall\ib project. questions as they arise
introduction
It's uncertain long-term project .
MF\HF definetly will Radian 950pb in p-audio ph2380 - 2380 clones(i have them already). perhaps biggest horns much later.
LF\MB - supposedly some custom big drivers in IB; until their early to discuss..
UHF - I'll think\deside later..
Cross - supposedly dcx2496. I'll order in the next few days.
Room in attachment (listening room - on right, 4.2*4.8 m, 20 m^2,).
Thanks for your input.
flesh flash flush
Old 29th June 2010, 11:11 PM   #2
Flaesh's Avatar
question 1.
where better to make a hole in the wall for horns? Toe-in or not?
I'd moved horns (alas w\o LF, 1order about 500 hz crossed) hither and thither. subjectively about 2.6-2.8 m between seems better than less distance for horns parallel to wall.
Also I tried corner placement toed-in 45 (I read some Wayn Parham texts and others similar..). May be, 4.2 m between speakers is too large distance or distance from listener to speakers is not enaugh? Right\left sounds gathers in right\left corners....
Toed-in with non-corner placement is contrary to flush-mounting..
Defined directivity horns (Everest like) seems unavailable..
Theortically, reconstruction of fron wall to \_/ shape is possible, but practically and now - ....
flesh flash flush
Old 30th June 2010, 12:45 AM   #3
GM is offline GM  United States
GM's Avatar
"Cult of the Infinitely Baffled"Hear The Bass, Not The Box The definitive online resource for Infinite Baffle subwoofer designEstablished 1999 - Home
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 30th June 2010, 01:05 AM   #4
Flaesh's Avatar
yes, I registred there last year and read many.
it slightly different cult.
I hope, praeps unresonable - I'll have no subwoofer..
And also I googled&googled flush\inwall\soffit mounted speakers.. Results: common phrase that is good, studio projects with speakers pointed at listening point and ugly set of wretched homecinemaspeakers for inwall mounting ..
flesh flash flush
Old 30th June 2010, 01:33 AM   #5
Flaesh's Avatar
p.s.: from Manuals
"The loudspeakers can be placed as close to the front wall as possible (mounting the speakers in the wall, in soffits, being ideal) ...(Users should consult with their Westlake dealer or the Westlake Audio technical staff for soffit mounting guidelines)."
do wright me to Westlake Audio technical staff ?
promise that I'll buy a pair of TM-3 monitors ( http://www.westlakeaudio.com/Speaker...ries/tm-3.html ), it seems unfair
flesh flash flush
Old 30th June 2010, 04:05 AM   #6
PeteMcK is offline PeteMcK
re:'Toe-in or not?' - depends on the directivity characteristics if the driver, and how you listen - sitting in one spot, or moving around? At least with boxes, you can change your mind.... and not affect the rear room so much too... although I guess you're prepared to sacrifice that room...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 30th June 2010, 04:42 AM   #7
Flaesh's Avatar
2380 is 90x40 horn.
I'm almost never sitting\listening exactly in "sweet spot". and I hate laserbeaming speakers.
I had some boxes&open baffles, and don't want now
I (almost)don't sacrifice room aria with this project relatively hundred liters boxes standing 3' from walls. and the wall I do not mind ..
flesh flash flush
flush\inwall\ib project. questions as they ariseHide this!Advertise here!
Some questions regarding sub-floor IB installation synessence Subwoofers 1 5th February 2010 10:27 PM
Home Theater Project w/ DIY In-wall 8945P speakers and IB subwoofer wigginjs Multi-Way 1 21st January 2010 07:21 PM
A few questions on a new project, please Misa A. Multi-Way 4 21st August 2006 09:04 PM
Anyone ever tried inwall dipole subwoofers. lion_rose Multi-Way 2 29th January 2004 01:41 AM
m&s inwall speakers shallenn Swap Meet 0 23rd September 2001 12:04 AM
